Question about Maytag Neptune MAH5500B Front Load Washer
How much does the washer weigh? - Maytag Neptune MAH5500B Front Load Washer
Washing machine balance problem
Since Washer Machine have become so Light in weight it is very critical to adjust the feet on the bottom of the machine so they are all touching evenly on the floor.. I had the same issue with my new Top Loader after retiring my 40 year old Washer. That old Kenmore weighed 2x what this new one weighs. I bet I don't get 40 years out of this toy
Jun 30, 2015 | Washing Machines
How do I take apart my washerr
How much does it weigh ? If it is beyond 33 kg avoid lifting it directly. Search for handles provided on either sides of washer. Just lift it slightly and ask someone to insert wooden platform under it. Now place washer on wooden platform and pull platform gradually. Avoid jerks during motion as washer may fall apart.
Oct 04, 2014 | Dryers
Maytag is clicking when its going to weigh clothes and spin at the end of cycle
It's a faulty relay on the control board. If you remove the top panel and remove the boards you will find a spot burned out on one of the relays. If you know how to solder then you might be able to repair it.
Mar 04, 2014 | Maytag Bravos MTW6600T Top Load Washer
Code ul
I move all the clothes around in the washer, leaving the center exposed. Sometimes it's just that a heavy towel or sweater has weighed one side down.
Dec 13, 2011 | Maytag Bravos MTW6600T Top Load Washer
Why does my washing machine have a knocking sound when spinning?
  • Try readjusting the clothes inside the washer tub and distribute them more evenly. When one side of the washer has more weight than one side and then is soaked with water it weighs that side of the tub down more and when it spins the tub bangs the side of the washer.
  • Get a level and make sure you plum it front to back and side to side to make sure it is nice and level.
Regards, Tony
May 20, 2011 | Miele Washing Machines
Kitchen scales & weights
Hope this helps,plz let me know
JonnieC
Weighing 1
006s1.gifWeigh 1 2 3 on the left and 4 5 6 on the right
If the weights are even go to Weighing 2a
If the left side is lighter go to Weighing 2b
If the right side is lighter go to Weighing 2c
Weighing 2a
006s2a.gifWeigh 7 on the left and 8 on the right
If the left side is lighter then weight 7 is the answer
If the right side is lighter then weight 8 is the answer
Weighing 2b
006s2b.gifWeigh 1 on the left and 2 on the right
If the weights are even then weight 3 is the answer
If the left side is lighter then weight 1 is the answer
If the right side is lighter then weight 2 is the answer
Weighing 2c
006s2c.gifWeigh 4 on the left and 5 on the right
If the weights are even then weight 6 is the answer
If the left side is lighter then weight 4 is the answer
If the right side is lighter then weight 5 is the answer
Mar 16, 2009 | Nintendo Professor Layton & the Curious...
All the water isn't spinning out of certain articles
i don't recommend washing heavy things in non commercial washers most will break under the strain.If you must, wash the heavy things alone.
Dec 14, 2008 | Kenmore 44042 Front Load Washer
Whirlpool Cabrio Washer Error message code F1
f1 code means the main control needs to be replaced. pretty common repair
Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Neptune MAH5500B Front Load Washer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
