Question about Konica Minolta Bizhub C253 With Document Feeder
How to set document feeder on top to work?
We had repair done on the main board and now the document feeder is not working.
  • Konica Minolta Master
  • 6,161 Answers
Sir/Mam,
Recommend that you have the technician come back out and reseat all the connectors he removed when in stalling the new circuit board. One connector mite not be seated properly or a connector pin was bent!!!
Posted on Jan 01, 2015
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
Tip
ERROR codes Canon 6150
Canon 6150 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E510 Sorter motor drive E530 Sorter home sensor E531 Stapler swing sensor E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 3825
Canon 3825 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
on Jan 18, 2010 | Office Equipment & Supplies
Document feeder door open
The doc feeder is the one on top, there's a sensor in the hinge at the rear. If the tab is broken from the top cover, you need to fold a piece of paper and put it inside the horse shoe shaped sensor to get past the error.
Nov 12, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Minolta Di251 Paper Feeder doesn't work. Need estimate to repair
Common problem with these models.....most likely if it sounds like it "tries" to feed you original then the feed rollers need to be cleaned. On the front left corner of the document feeder cover there is a single screw. Remove the screw, open the F1 door and the cover will come off. Now right where the originals feed in you will see 4 feed rollers or small "tires" The 2 smaller ones or the usually the main cause. Just take a cloth with some glass cleaner on it and rotate and cleaned both sets of tires. Reinstall the cover and you should be good to go.
Oct 14, 2009 | Konica Minolta DiALTA Di200 Copier
Tip
ERROR codes Canon 3325
Canon 3325 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
Will not scan from glass but feeder will?
Using your scanner program such as PaperPort, you really have to pay attention on where the document/photo is located for scanning.
Steps
1. Click on Start, Programs, Paperport
2. Right above the Word "SCAN", you will have several options on;
a. Document or Photo
b. Flatbed or Feeder
3. Once step 2b has been selected, the M20i will scan your document per your instructions.
Note:#1
If you place your document on Flatbed but your selection on your screen says "Feeder" where do you think the scanner will look for your document? The answer is --> Feeder!!!
Note #2
Make sure that you click Accept,& DONE, other wise M20i will just sit and wait for your next command.
I hope this resolves the confusion between GLASS and FEEDER scanning.
Jun 29, 2009 | Xerox WorkCentre M20i All-In-One Laser...
File System Setup Message
It sounds like you have a main circuit board failure.
However, try this.
Open the toner door and remove the cartridge
make sure the machine is turned ON
Unplug the power cord
open up the document feeder by pulling straight up
hold down the pointed black switch
closest to the small glass while plugging the power cord back in until you hear a BEEP, close the document feeder.
scroll down to SHIPMENT SET
press SET
press 2
SET
The machine will REBOOT in 2 minutes.
Good Luck.
Dec 03, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
HP 3055 model scaner problem
Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 02, 2008 | HP LaserJet 3055 All-In-One Printer
Panasonic copier/fax UF 885
It sounds like you are stuck in the boot-up mode.
Try this:
Turn the machine off
Open the document feeder by pulling straight up
While turning the machine back on, hold down the pointed switch actuator closest to the small glass
Close the document feeder..display should read "RAM INITIALIZE"
Scroll down to "SHIPMENT SET"
Press "SET"
Press "2" for "NO"
Wait for the machine to reboot (could take 5 mins)
Some times a bad toner cartridge will cause this.
If this does not work, you have a bad Main PC Board. Uneconomical to repair.
Sep 19, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Konica Minolta Bizhub C253 With Document Feeder Logo
63 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
