Question about Kenmore HE5 Electric Dryer
How to run diagnostic check on kemore he5 - Kenmore HE5 Electric Dryer
Dryer won't run check lint screen light comes on
Did you check the obvious by turning off the 30 amp double breaker and turning it back on
Nov 30, 2013 | Kenmore HE5 Steam 7.5 cu. ft. Electric...
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
Kenmore Elite Smartheat He5 front load dryer will not run more than 1 min, stops & turns off. Any ideas?? (Lint cleaned out, does not work regardless how much or how little is in dryer)
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 30, 2010 | Kenmore HE5 Electric Dryer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair - The dryer will not start
heatman101
Error F13 on Kenmore dryer He5
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 17, 2010 | Kenmore HE5 Electric Dryer
Just bought a new HE5 dryer three days ago and used it for the first time---the sides of the HE5 dryer are extremely hot (could burn hand), is that normal and what could be the cause?
check the vent line,could be clogged with lint if you never cleaned it,you should clean out your dryer every year by taking off and cleaning out the duct that the lint filter slides into,vac out the inside of dryer and clean out the vent line,if it's a long run from the wall to the outside vent hood blow it out with a leaf blower,go outside and make sure the air is blowing out with force,all a dryer does is move air and if something is blocking the air flow the dryer will get hot,you'll start blowing thermostats or the thermal fuse because they are safety switches so if the dryer does run to hot they pop and shut down the dryer so hopefully you don't have a fire or damage the dryer
Jan 10, 2010 | Kenmore HE5 Electric Dryer
Kenmore HE5 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
