C12AWU ue0 lg artcool air conditioner
Outdoor unit PC wiring and test signals
Therinnaiguy
  • 1420 Answers
SOURCE: Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Posted on Oct 10, 2007
  • 86 Answers
SOURCE: Error CA for LG air conditioner model Q-12 AWR
1.sensar of remote control.
2.indoor unit sirkit board may be there is problem.change sirkit board by new one
3.if any requirement abt airconditioner pls mail me i can send u spare parts of air conditioner,.
mintex007@yahoo.com
Posted on Mar 16, 2008
  • 140 Answers
SOURCE: Unit constantly makes a clicking noise.
Electronic filters use static dicharges to filter the air. Unfortunately the make that clicking noise when they discharge. LG calls it a plasma filter. Clean both the regular and the plasma filter to see if that helps.
Posted on Dec 30, 2008
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 1250 Answers
SOURCE: Airforce 12000BTU Air Conditioner wiring problem
The outdoor unit should have 2 small wires connected to the contactor coil. This delivers the 24v "Signal" to energize the coil. The wire from the t'stat for cooling are usually yellow, in almost every case. When you put the t'stat in the cooling mode and set the temp lower than the room temp, the indoor and outdoor unit should come on. Check for voltage on the terminal block for 24 volts accross the yellow and common wire. Common could be ground on some handlers. If you have the 24 volts, then check for 24v on the 2 small wires (usually 18 to 22 gage wire) on the contactor coil. If no voltage, trace the 2 wires back to the indoor unit and see where they go. If they are the ones that are not attached, put one on the yellow wire terminal and the other on the common terminal. This will send power to the indoor unit and then piggyback to the outdoor unit. Do not remove the yellow and common from the terminal block. Don't be too concerned about the colors from the outdoor coil wires. Just make sure they are hooked up right. Good Luck and hope this gets it going.
Posted on Jun 07, 2009
Hi, I have an LG artcool A09AHD aircon unit and after a while on the heat cycle, the unit stops and shows a circle with a snowflake and a waterdrop within the circle. Does anybody know what alarm tjis is?...
This may just be the defrost cycle for the outdoor unit. In the heat mode, the outdoor unit builds frost on the coil. The outdoor unit senses how much frost has built up on the coil and reverses the refrigerant cycle to allow the outdoor coil to warm up and defrost it. After a short period, the unit then restores itself to the heat cycle. This is normal operation and nothing to worry about. During the defrost cycle, you may feel some cool air inside your home.
Oct 26, 2013 | LG Heating & Cooling
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
LG Artcool about 4 yrs old error code CH 05. no heating or cooling. cheers.
CH 5 on these machines indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assy to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts stockist.
Jun 16, 2011 | Heating & Cooling
I have a LG Artcool LAN121HNP the unit will only ciculate air (not cool) it is only 2 years old. I have had an HVAC guy look at it, he says the compressor is fine. We have put a new board in the outside...
Make sure none of the thermostat wires from the inside unit to the outside unit have come loose or have be cut by a weed eater or such. These units are a little more complex than your average heat pump.
Aug 24, 2010 | LG Art Cool LA181CNW Split System Air...
Installed an artcool in my appartment and it constanly leaves a little puddle of water on the floor, irregardless of the temp setting or the fan speed. Drain hose is connected to the plumbing drain. Water...
first of all check the outdoor unit if it is in your reach  than simply touch both the valve & feel the temp if smaller valve is colder than the bigger one than surely the problem is with refrigerant quantity.
Jul 20, 2010 | LG Art Cool LA1000PR Air Conditioner
My Artcool a/c internal unit began dripping alot of water after being used for 4 hours.... any ideas?
rochelle2511
I have an LG artcool unit too, with the same water problem. Have you found a solution?
Brad
b.emberton@comcast.net
Feb 12, 2010 | LG Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
