Question about LG Studioworks 563N 15" CRT Monitor
About VGA Cable
My monitor's VGA Cable is cut by a mice.thatswhy monitor cant get signal. so how to change the VGA Cable?
4 Suggested Answers
SOURCE: 710s monitor wiring diagram to vga plug
DRIVER OF MONITOR LG 710S
Posted on Feb 28, 2008
rmoseng
  • 77 Answers
SOURCE: I can't get a signal between my PowerMac G5 and my
First we need to know your G5 and monitor are working, independently. Test these items first on known good computers and monitors. If they show working then;
If your G5 is per 1997 then it may be a true compatibility problem. If 1997 or later, then it could be one of several problems.
1. video card not working or not powerful enough or overheating
2. G5 power supply issues
3. video card may need to be re-seated
4. 3rd party RAM compatibility issues
5. try by resetting the PRAM
6. The monitor may have the brightness and contrast set to BLACK
7. The G5 DVI output may be off or failed.
8. You can try this fix;
Go into System Preferences > Displays > Options (on the 2nd display) and selected "Disable Power Button". Problem solved, if inelegantly.
OR
change the other settings for displays.
9. Using the on-screen settings on the monitor, change to the lowest resolution, then if visible work your way up until it goes blank again.
See some supporting info here:
http://support.apple.com/kb/TA27012
and
http://support.apple.com/kb/HT2707
and
Here is you manual:
http://manuals.info.apple.com/en_US/PowerMacG5_UserGuide.pdf
Good luck
Posted on Dec 14, 2009
Slasher_X
  • 767 Answers
SOURCE: hello I just purchased a LG
The DVI cable must be faulty as the card does work with the VGA cable as you have stated.
Posted on Jul 10, 2011
No signal
Press the Function Button to open the short cut menu. Locate the Input graphic and press the button for it. Each time you press the button, it will cycle between DVI and VGA input jacks. Allow a few seconds for the display to switch inputs. Make sure that cable is connected securely to the associated jack in the back of the monitor and the computer (or other source). If either VGA or DVI input is selected ,but the VGA and DVI cables are not connected, a floating dialog box indicates:
"No Cable Connect" or "No Signal"
Your manual can be viewed here:
http://www.manualslib.com/manual/268264/Acer-S201hl.html#manual
Apr 07, 2014 | Acer S201HL BD Refurbished LCD Monitor
LG monitor displays "D-SUB POWER SAVING MODE" when it is starting
The message it is displaying indicates that a VGA cable is connected and is not sending signal, or is sending a Monitor Off signal across the VGA cable. The motherboard battery will have no impact on this. If you are using something other than a VGA cable to send the signal to the monitor, then you should ensure that no VGA cable is plugged into the monitor, or the source on the monitor is not using the VGA connector.
Mar 28, 2014 | Computers & Internet
My monitor wont recieve any signal from my computer
sir your monitor's VGA cable is not fine replace it and it will work fine get a new VGA cable from market and replace it then it will work fine.
Thank you
Mar 31, 2012 | Think Computer Computers & Internet
LG W2361V 23 Vga to HDMI Cable Not Working
You have a cable problem as no such thing as a VGA to HDMI cable exists.
HDMI is a didital signal and is thus not compatable with an anolog VGA signal. HDMI to DVI cables however do exist as both are digital signals.
Hope this helps.
May 28, 2010 | LG W2361V-PF 23 in. Widescreen LCD Monitor
VGA problem with HP monitor
The VGA cable are standard pin out for VGA DB15HD connector.
Learn about it here: http://en.wikipedia.org/wiki/VGA_connector
Apr 02, 2010 | Computers & Internet
My VGA plug is missing on my monitor
If the cable does not disconnect from the monitor, then go ahead and buy a new connector http://www.startech.com/item/C15HPSM-High-Density-DB15-Male-VGA-Solder-Connector.aspx
I recomend this over buying a generic VGA cable and splicing wires, for better connectivity and less 'noise'.
Aug 06, 2009 | Neovo F-417 17" LCD Monitor
My monitor was not red colour
Change the vga cord of your monitor. red,geen and blue signal from cpu to color monitor pass tru vga cord. if one line is cut for example red line is cut 100% there is no red color in your monitor.
Jan 06, 2009 | Computers & Internet
VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Jul 22, 2008 | Samsung 793S 17" CRT Monitor
LG Studioworks 563N 15" CRT Monitor Logo
16 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
