Question about Sole Fitness Sole E35 Elliptical
Sole elliptical pedals stuck
Wheel seems stuck and pedal don't move
How do I stop the squeaking noise when pedaling the bike or using the elliptical option? I've tried lubrication. Only getting worse.
Have you lubricated all moving parts. Wheel bearings Chain and sprockets? Are there fenders if so are they a little loose?. Anything that is loose will vibrate and make a noise. Even dry pedals will make a noise. Crank also.Just a thought.
Dec 23, 2016 | Exercise & Fitness
We folded the Proform 500 LE Elliptical and moved it. Now we are unable to unfold the elliptical with the latch button. Suggestions?
HOW TO FOLD AND UNFOLD THE ELLIPTICAL
When the elliptical is not in use, the frame can be folded out of the way. First, lift the latch under each pedal arm, and lift the pedal arms off the adjustment sleeves on the crank arms.
Next, raise the pedal arms until they touch the magnets on the upper body legs; the magnets will hold the pedal arms in place.
Then, hold the handle and lift the frame until it locks in a vertical position. To use the elliptical, first hold the handle, press the latch button, and lower the frame.
Next, pull the pedal arms off the magnets on the upper body legs.
Then, lift the latches under the pedal arms, and set the pedal arms on the adjustment sleeves on the crank arms.
Release the latches, and make sure that the pedal arms are securely connected to the adjustment sleeves.
Will be attaching a link to your manual also
http://www.sportsmith.net/images/product_support/ProForm/PFEVEL959101%20-%20PROFORM%20500%20ZLE%20ELLIPTICAL/PFEVEL95910.1-307585.pdf
May 25, 2015 | Proform Exercise & Fitness
Why is the the resistance on my sole e55 remaining easy to spin regardless of which resistance setting I select?
Belt could have come off. if the belt did break or come of it would be very easy to spin pedals. Flywheel ( brake ) could have jammed up. Loosen the covers and look for the brake cable that's connected to the resistance motor. Then run the resistance up to 20. If cable feels loose , the brake is stuck. Sometimes you can pull on the cable and it will free it up.
Aug 30, 2014 | Sole Fitness Sole E55 Elliptical
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
May 29, 2014 | Exercise & Fitness
In what way is an elliptical trainer different from a treadmill?
Treadmills have a moving belt while elliptical trainers have two foot pedals guiding movement - making it more controlled and safer. Elliptical trainers also have handles, in which the user has the option to move their arms in opposition to their legs to better control movement.
Aug 02, 2012 | Exercise & Fitness
NordicTrack CX 1055 Elliptical ramp pedal wheels
Hi, You can find them easily on amazon, click here ant take a look: Amazon com Elliptical ramp pedal wheels. Wish you best of luck. Cheers
Jun 22, 2012 | Exercise & Fitness
Just put together the proform 500 le elliptical and can't pedal. It seems like its stuck.
Dear Sir:
Check is sliping, if do use the tool wrench for adjustmente the bolts.
2( See is the axis is not bend, if do you must replace it the machine, because is the hear of the elliptical.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 14, 2012 | Exercise & Fitness
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Error code 1 on schwinn elliptical 418 how do I fix it. I have replace batteries and unplugged unit. Error 1 shows up as soon as I turn unit on.
E1 error seems to indicate that the servo which controls the elliptical resistance is stuck. Here is how I fixed this (without using a "crank puller", which would be quicker by far).
You will need a very short phillips screw driver (snub nose), a long phillips screw driver, an allen key set, and crescent wrench.
- Remove the batteries from the unit.
- Remove the screws from the plastic housing (with the long phillips screw driver) on the left side. Do not forget the phillips screws at the front - they are smaller screws so don't mix them with the others. This will allow the plastic housing to flex and move around, but not come entirely off.
- Using the crescent wrench, remove the nut holding the left pedal to the crank. Carefully note the order of the washers on the crank attachment.
- Using the allen key, remove the little pedal attachment piece on the left crank arm.
- Using the short phillips screw driver, carefully reach inside the plastic housing on the top and remove the four screws holding the plastic plate on the outside of the fly wheel/crank. You will need to rotate the crank wheel to reach each of the four screws in turn on the inside of the case.
- Pull off the plastic cover for the wheel.
- Reinsert batteries and gently help the revealed cable (bottom) retract the magnet plate. In my case, the servo worked fine again after helping it retract the magnet plate that was somehow stuck/wedged.
Reverse steps to re-assemble.
Jan 16, 2010 | Schwinn 430 Elliptical Trainer
Driving Force Pro pedal pots are dead
had the same problem just take one pot off and take it to your local electrics store ask for replacement. also try bathing them in wd40 that worked for me for about year until i replaced the original cheapos
May 12, 2008 | Logitech Driving Force Pro (963293) Wheel...
Sole Fitness Sole E35 Elliptical Logo
22 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
