Question about Westinghouse WWSR1 Iron
No steam comes out
Iron heats up
My Super PRO vaporetta iron heats up but no steam comes out ....help.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber.
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
Feb 27, 2013 | Irons
My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 14, 2012 | Irons
My steam iron does not produce steam it heats up good but no steam comes out
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 29, 2010 | Rowenta Steam Generator DG050 Iron
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2010 | Black & Decker Steam Xpress AS250 Iron...
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
No steam. I pressed the steam button on the underside of iron handle and no staem.
There 's a leaked capacitor in the circuit board. You just have to replace it and it works again.
Please visit the following page for detailed instructions:
http://thechipfreak.blogspot.com
Jan 15, 2010 | Rowenta DG5030 Iron
The iron seems like it is on but no steams come out I will mess with the wire and then too much steams comes out and I have water stains
Power Cord is bad and power cuts on and off not allowing the proper heat. When power cuts off you lose heat and the iron fills up with water and not steam then when power returns you have to much steam.
Jul 17, 2009 | Rowenta Irons
Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Sep 10, 2006 | Euro-Pro Steam Generator EP8020 Iron
Westinghouse WWSR1 Iron Logo
75 people viewed this question
Top Westinghouse Irons Experts
Are you a Westinghouse Iron Expert? Answer questions, earn points and help others
