House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
The circut breaker in the house keeps tripping. Is this a compressor problem that can be fixed without replacing the entire compressor?
Yes yes this is what mines doing, We have a weather king about 4 or 5 years old it blows air but not cold just air, the outside is blowing cold out the top and not leaking water please tell me more explain what I can do to fix it... :(
My weather king is 5 years old and will work just fine for a while days, than the next min, just a day or a couple of hours.Then it will not come on at all for a couple of hours??? I was having a problem with it coming on but no cool air we put freon in it and it worked great the first night, next day it was blowing cool out of the fan and the pipes on the back of the outside unit were both luck warm. on the smaller tube that is suppose to be warm, there is a direr filter blue and round, it was frozen from the far side the part that goes into the house its copper it was white with ice, but the tube below the filter that goes into the unit was fine ????? I guess I have two problems can some one help me please. We didn't have gauges so we were told to feel the pipes on the bottom backside of the unit,one should be warm and the other cold, this is what we did did we fill it to much???
