Question about Home
How do I change the valve. On a franke DW-100 faucet. Is the handle pressed on? ranke instructions
jj505
  • 195 Answers
SOURCE: single handle pull out Franke faucet stopped working
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
  • 23 Answers
SOURCE: turn hot handle on - water does not come out of faucet
is the feed on the bottom of the sink open . if it is shut the water off from the bottom and take apart the handle to see if something is stuck in there
Posted on Sep 26, 2009
bearsfan7538
  • 119 Answers
SOURCE: What tool and what size of this tool is needed to
You need an allen wrench set
Posted on Nov 28, 2009
  • 10865 Answers
SOURCE: We have a 1986 single-handle
Hello feleppa... Most faucets can be repaired. That said, if you can not figure out how to disassemble it you could consider removing the entire faucet and taking it to the hardware store. Most hardware stores are expert at repairing faucets, if the parts are still available.
That said, this faucet is 26 years old so getting parts may be a challenge. My advice to customers in this situation is to put the repair money toward a replacement, unless the faucet has sentimental value.
Joe
Thanks for choosing Fixya!
Posted on Jan 16, 2011
  • 1456 Answers
SOURCE: I have a four year
Hello
Physically inspect your microwave. Open the door and look at the seal surrounding the door. Remove any debris or food particles from the microwave and the seal by regularly wiping them down with a soapy dishcloth. Close the door and look for any spaces or loosened seals at the contact points. Inspect the door and trim for any bulges, gaps or rattling.
Wipe the microwave's exterior and ventilation ports. Inspect for dust or debris that could block airflow to the microwave.
If a leak is suspected or indicated, take the microwave to an authorized appliance repair center. Do not depend on a non-FDA approved meter to detect accurate levels of radiation.
Check your local yellow pages or search the Internet to find an authorized appliance repair center in your area.
THANK YOU
Posted on Jun 13, 2011
How to remove moen bath faucet handle that has no set screws and is all 1 piece
1.) its not all one piece
2.) the tower threads onto the valve body, you may need to loosen the mounting nut under the sink top with a basin wrench to relieve the pressure on the handle tower
3.) this is the exploded parts view for your faucet: http://www.moen.com/shared/docs/exploded-parts-views/s498pt.pdf
4.) this is the instruction sheet for your faucet, including a technical support number you can call: http://www.moen.com/shared/docs/instruction-sheets/ins1207.pdf
Aug 26, 2014 | Moen Showhouse S498 Savvy Two Handle...
How do I remove a seized handle on my FF-600 Franke faucet.
Refer to the link for drawing of the FF.660.
It looks like the Cover 45019 attaches to the faucet body I would brush some vinegar on/in any openings around this part for several minutes then heat the cover by pouring hot water over it after that use a Strap Wrench to try to turn the cover anti clockwise. It may take a few tries to dislodge the corrosion before it will release. Repeat with Valve 3699 and a wrench.
http://www.guillens.com/faucetparts/franke/images/FF600.jpg
Nov 10, 2013 | Plumbing
LOW WATER PRESURE FROM A FRANKE KITCHEN FAUCET
There probably is sediment where the water is coming at the valve. Remove the head of the faucet and clean it . This normally is the problem.
Dec 24, 2012 | Franke FF-303 Kitchen Faucet with...
Hansgrohe axor faucet jammed
On this model the escutcheons will turn counter clockwise and the whole handle will lift off as one unit. In some cases water deposits can cause the handle to stick and you may need to use CLR to lossen the deposits. In some other cases installers will put the handle on first and then tighten the valve to the deck. This causes the handle to be too tight to the deck and can strip the handle fixation. Try loosening the the valve set below the handle and see if the handle is easier to remove once the valve is loosened. If you need further help feel free to contact me at Hansgrohe Technical Services at 1-800-334-0455. Press 2 for Tech and ask for David Scarborough.
Sep 16, 2012 | Hansgrohe 31063001 Metris S Widespread...
Hello i have a franke kitchen faucet #fff303 and the spray head is not working is there a replacment head you can send me?
There are websites that give instructions for disassembling the Franke faucets. Also, some have a valve cartridge ($20-50) that can be replaced (you take the handle off, the catridge is inside)/
Jun 15, 2011 | Franke FF-303 Kitchen Faucet with...
I have very little water press on the hot water side
Dis-assemble the faucet to get to the valve. The handle comes off and you access the valve from the top, usually by removing a screw on ring.
You will robably find contamination in the hot side of the valve.
You can find instructions on the Moen website.
Sep 09, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Hi, I have a Franke FF600 with a serious low flow problem. Thanks
The undersink flow restrictor, attached at the end of the flexible "hose", was clogged. Verified this problem with Franke USA. In support of their product they are sending out a replacement flow restrictor for FREE!
Aug 25, 2009 | Franke PF3000Series Deck Mounted Pot...
Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
Jun 25, 2009 | Delta & Single Handle Shower Faucet
Single handle pull out Franke faucet stopped working
Apr 05, 2009 | Franke Plumbing
Home Logo
132 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
