Question about Lexmark T642 Laser Printer
914.00 SERVICE DC PICK MOTOR
WHEN I PRINT MY PRINTER DISPLAY 914.00 SERVICE DC PICK MOTOR.WHY?
2 Suggested Answers
  • 5 Answers
SOURCE: Error message service dc pick motor on screen
Get new rollers.
They are held on with a little clip you push in and the wheel slides right off
Posted on May 07, 2010
My hp p4515 printer has an error of 59.50 7 59.40 how i can solve this problem.
59 error is a problem with the drum motor on printer. This is usually caused by a bad print cartridge, so try a new print cartridge first. If that does not solve the problem, use the control panel (up and down arrows to move options, green button to select) Arrow till display reads diagnostics, select, arrow down till display reads "component test, select and then find the drum motor test and select. If you do not hear the motor rotate then either the motor is bad or the DC controller is bad. Motor is the easiest to change and if printer appears to work otherwise, it would be the first component I would replace.
Aug 04, 2014 | HP LaserJet P4515 P4515N Laser Printer -...
COMO RESOLVO ESSE PROBLEMA HP M4345X ERRO 59.40
59.4 = Print-cartridge-motor error
TRY THIS
1 Turn the MFP off, and then turn the
MFP on.
2 Reconnect the wire-harness on the dc
controller PCA for the motor that is
indicated. For the main motor, this is
connector J98. For the print-cartridge
motor, this is connector J86.
3 Replace the motor. See Main motor
(M101) or Print-cartridge motor (M102).
4 Replace the dc controller PCA.
Jul 02, 2011 | HP LaserJet M4345 MultiFunction Printer
57 service
57 (or 57.1) SERVICE Message (Main Motor Failure)
The 57 SERVICE indicates that the DC Controller PCA detected a
general motor failure. The Main Motor drives all moving
components in the printing process. The Main Motor is a 4-phase,
DC servo motor controlled by the DC Controller PCA.
The formatter detects a Main Motor failure when:
• The Main Motor does not come up to speed within one second
of receiving drive voltage.
• The Main Motor deviates from the correct speed for one second
after reaching the correct speed.
Main Motor Functional Checks
• Inspect the gear train for debris that would block the free
operation of the gears.
• Check the gears in the Toner Cartridge for wear and binding.
• Reseat J211 (or J214 on the HP LaserJet 4 Plus/4M Plus) on
the DC Controller PCA, and the main connector on the Main
Motor Assembly. Refer to Figures 7-16 and 7-17 for the DC
Controller PCA connector locations.
• If the problem persists, check that the +24B Voltage is present
on the DC Controller. If the voltage is not present, replace the
DC Controller. If the voltage is present, and the motor does
not rotate, replace the Main Motor Assembly (see Figure 7-11
for location).
Oct 21, 2010 | HP LaserJet 4 plus Printer
What does 914 Service DC Pick Motor mean?
Printer Error Codes 910,911,912,913 and 914 are indications that a Tray 1 paper feed problem has been detected. It's what i found hope it helps
Sep 28, 2010 | IBM Infoprint 1352 Laser Printer
Hp color laser jet printer is displaying error 59.co on the display pannel
Developing disengaging motor error
. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step
May 14, 2010 | HP LaserJet 4700 Printer
Get new rollers.
Dec 27, 2009 | Lexmark T640 Laser Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Printer error code 5952 - ?
From the service manual:
An error occurred with the magenta printcartridge drive motor during startup or rotation.
To fix:
1. Check that connectors J5003 on the magenta print-cartridge drive motor and J207 on the DC controller are seated correctly. If they are then:
2. Replace the magenta print-cartridge drive motor. If that doesn't work then:
3. Replace the DC controller.
Jul 08, 2009 | HP LaserJet 3600n Printer
HP LASERJET 4 PRINTER
Failure)
Nov 06, 2008 | HP LaserJet 4 plus Printer
My printer cartridge jams and it doesn't pick up the message from the computer
did you connect the cable correctly to your computer therefore the computer unable to pick up the message.
Jun 26, 2008 | HP Office Equipment & Supplies
Lexmark T642 Laser Printer Logo
992 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
