Lanier ld425c .. when I print, there are faded black color lines at the bottom of the pages
5 Suggested Answers
SOURCE: A faded line prints across the page
The imaging bar has speck of dust on it.
Turn printer OFF.
Open the printer. Pull out the transfer roller. Should have a big green handle. Do not touch the roller.
Look inside for a shiny rectangular block about 5inches x 0.5 inch.
This is the imaging bar. Using a lint free cloth with no chemical and no water, gently wipe this bar to remove any specks of dust/paper specks.
Put roller back.
Close the printer.
Turn printer ON.
Problem fixed.
Posted on Dec 04, 2008
  • 46 Answers
SOURCE: line down one side of page.
One of the ink nossels are blocked you can use benzien or hot water to unblock them
Posted on Oct 16, 2009
SOURCE: Why am I getting lines on my prints when I go thru the top feed of my Lanier LD425C?
Clean the **** glass. It is a long skinny glass to the left of the big rectangular glass under the feeder. Clean it and your problem should go away.
Posted on Aug 30, 2012
  • 193 Answers
SOURCE: hp color laserjet black print fades to the bottom of the page.
check transfer belt.
Posted on Sep 28, 2013
How to print enevelopes without them jamming in a lanier ld425c
in bypass put envelopes in short edge first, push the # button, select size of envelopes and OK it, (needs to be told of size)-Carl
Aug 28, 2014 | Lanier Ld445c Ld435c Ld430c Ld425c Ld420c...
Dsc224 color print misalignement
This model is infamous for this. Not a job for those without experience.
Aug 27, 2014 | Ricoh 1224c 1232c Gestetner DSC224 DSC232...
Colors don't line up correctly
This problem is referred to as color to color alignment. Most color laser systems have a rough adjustment by means of a screw somewhere and a fine adjustment that is done in diagnostic mode as part of a setup routine. Try the latter first by locating your manual and looking through the troubleshooting guide which should explain how to force the machine to do an automatic color alignment. Your manual should be available online from your manufacturer's web site if you can't locate it. If this doesn't work you will need to take it in for servicing unless you are handy with tools and can find a service guide for your model.
Nov 10, 2013 | Lanier Ld445c Ld435c Ld430c Ld425c Ld420c...
Lanier LD425c touch screen does not function
You can try to adjust the touch screen > press the yellow clear button then 1993 & press the stop button three times & follow the display screen. Odds are you are going to have to replace the touch screen, the adjustment will not last long....Good Luck
Dec 22, 2012 | Ricoh Lanier Ld445c Ld435c Ld430c Ld425c...
Aug 30, 2012 | Lanier Office Equipment & Supplies
Hp color laserjet black print fades to the bottom of the page.
dirty scanner.open the printer back cover.remove the scanner assembly clean it ,do the color calibration.u should be fine.
Amuna1
Jun 30, 2010 | HP Color LaserJet 2600n Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Magicolor 2400W print fades on right side of page
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
May 12, 2008 | Konica Minolta magicolor 2400 Laser...
23 people viewed this question
k24674
jasbo
jasbo
