Question about Mitsubishi WD-65736 Television
Ststus light is red on my wd-65736 - Mitsubishi WD-65736 Television
3 Suggested Answers
  • 101 Answers
SOURCE: Need help with Harmony One remote and Mits WD-65736
To ensure the remote controls your devices properly, you must disable Net Command.To disable Net Command you must delete all devices associated with it.
Open the Mitsubishi Television's setup menu.
Select Delete at the setup menu.
Select Entire Configuration and then select Next.
Follow the onscreen instructions to delete the entire configuration.
To finalize your selections and complete the NetCommand setup, select Finish from the finish screen.
#messageContent0_1 {font:10pt Tahoma,Verdana,sans-serif;}
Posted on Feb 04, 2010
  • 9 Answers
SOURCE: i have a mitsubishi wd-65736 no picture just sound
do you have a red lamp light on, if so you need to replace the lamp
Posted on Nov 28, 2010
My Mitsubishi WD 65736 TV has a bad Fan ... according to a tech that came out . How do I tell which of the 3 fans is bad .. all 3 come on for about 15 seconds then shut down all at once ... start up again...
Hello, count the blinking light pattern. It may blink 2 to 9 times, pause and repeat the pattern again. Does it ever light the screen when it's cycling on and off? Let me know....tks
Feb 24, 2015 | Mitsubishi WD Televison & Video
Blinking status green light red
The most common issue for this TV is the lamp.
If the current lamp in the TV set is around 2-3 years old then I would start with that. If the lamp is not original they only last about 1 year.
If you already replaced the lamp recently the next step is the ballast.
I hope my answer was helpful :)
Oct 08, 2013 | Mitsubishi WD-65736 Television
Status light red
The problem is most likely the lamp.
They usually last 2-3 years if original.
Status light flashing
You have the V39 Chassis and if the status light is blinking Red then its indicating the fan has stopped. There are more than one you can get the assistance to determine which one you need from www.tvrepairworld.com and they also have the replacement fans that come with installation instructions.
Mar 22, 2013 | Mitsubishi WD-65736 Television
I just replaced my bulb on my mitsubishi wd-65736 but picture is still dark looking and the bulb stays lit up after we cut the TV off. Could I have hooked the two wires up wrong?
This site lists your service manual for $7.99
https://www.completeservicemanuals.com/mitsubishi/dlp-projection-television/wd-65736-service-manual/prod_1408.html
This site claims to have a free PDF download, but the "free download" link throws you to www.tradebit.com, which sells the service manual (as a downloadable PDF file) for $7.99
http://www.promanuals.com/serviceparts/mitsubishi-wd-60735-wd-65735-wd-73735-wd-65835-wd-73835-wd-60c8-wd-65c8-wd-73c8-wd-65736-wd-73736-service-manual/
This site sells your TV service manual for $5 as a .PDF sent to your email:
http://tv-part.com/index.php?target=products&product_id=1369
If you can read/use a service manual, $5+tax is a lot better than $hundreds for a new television. Or- buy the downloadable manual, and give it to your favorite electronics friend to peruse. The darkness coming from the new lamp might bespeak of a power supply problem, or a poor connection between the lamp and the power supply. The fact that the lamp module stays on after it should go out also says power supply problem.
In the worst case, keep both your lamp modules (they're probably both good), and sell them online to help defray the cost of a new television.
Sep 30, 2011 | Mitsubishi WD-65736 Television
I have a mitsubishi wd-65736 no picture just sound
Nov 28, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Feb 01, 2010 | Mitsubishi WD-65736 Television
Making clicking sound when turning on but won't come on then green light goes out and red lamp light comes on
You need to replace the lamp. It is located in the back on the lower right side. It costs around $130.00 with the housing and only takes 5-10 minutes to change. You need to remove about 5 screws and slide the lamp out then slide the new one in and replace screws. Hope this helps.
Jul 09, 2009 | Mitsubishi WD-65736 Television
Mitsubishi WD-65736 Television Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
