Question about Zenith MBR3458T MBR3458T Universal Remote Cable/Vcr/Tv P/N: Mbr
Zenith MBR3458T Universal Remote Cable/VCR/TV codes
informatica
  • 1114 Answers
SOURCE: ZENITH UNIVERSAL REMOTE CONTROL
There seems to be only one manual covering all the universal remotes from Zenith. The website is on the link below: http://www.zenithservice.com/ Go to "owners manuals" then scroll down to the center panel & select accessory & go to second page. The document is called "Zenith_ZEN100-ZEN700_RemoteManual" Sorry this is so complicated but Zenith don't allow direct linking to this page.
Posted on Jul 29, 2007
freetek
  • 5568 Answers
SOURCE: toshiba tv code for Zenith remote
Check the manual for your Zenith; many of the Zeniths (and many others) have a 'scan' mode you can call up, in which you can repeatedly press one key (^ for example), then the Power Button. That will force the remote to set every code it has available, step by step.
If you no longer have the manual, you may find it here or several other sites that offer these.
Posted on Apr 09, 2008
SOURCE: Code for zenith remote control for toshiba tv
I found the code
Posted on May 22, 2008
SOURCE: programming
push the tv button then hold down the code search button till the light becomes solid. point the remote at your tv while it is turned on and push the channel up or down til the cannel changes. once it does push the mute key to save. so u know this works like that on all device and if you pass up the right on from pushing the button too fast you can just push the opposit direction rather than waiting for full circle. also be aware that there are multiple codes for some devices and some work better than others.
Posted on Aug 26, 2008
SOURCE: wHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Posted on Feb 03, 2009
Need remote code for zenith tv/vcr TVBRO922Z
You can try using a universal remote control and performing a code search. If nothing is found, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Nov 22, 2017 | Zenith Televison & Video
Zenith TVBR1322 9 In. Combo universal code
Universal remotes will be missing key functions in these units.
Zenith (and for that matter most brands) do not make these units--about 4 companies make most of them.
Your best bet is to try to locate an original remote--Zenith(LG) or Google the model number "original remote" or even search EBAY.
Mar 21, 2012 | Zenith TVBR0922Z 9 in. Combo
HOW TO PROGRAM RCA RCU430 UNIVERSAL REMOTE CONTROL TO A ZENITH TV
Hello Lorielevi,
Follow the steps below.
Press and "HOLD" CODE SEARCH.
Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
Enter the three digit code from the TV, VCR or Cable Box code at the bottom.
Release CODE SEARCH.
With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
here are the code for Zenith 001 056,061,068
hope this sort you out. If it does then please leave a thumbs up
Cheers Little Dish Fitter.
Oct 16, 2009 | RCA Universal Remote Control
Need Universal Remote code for Zenith VCR/TV Combo TVBR19422
both together in a code or separate in brax 0226...0227...0247...0266...0288..0310..0338..0358.[0039 0252][0153 0245][0138 0279] [tvcode vcr code]
Oct 09, 2009 | Zenith TVBR1924 19 in. Combo
Cox Universal Remote Won't Work for Zenith VCR
Try the Cox website's pdf. for this universale remote. I hope this is it and good luck to you. Sincerely, CBR2009 http://www.cox.com/support/cable/pdf/universalremote04.pdf
Jul 11, 2009 | Zenith DBZN-311 Remote Control
Need universal code for philips sru3004 universal remote
here are some sites with your code.
www.remote-codes.com
www.tvcodes.com
www.universal-remote.net/philipsmagnavox.html
Apr 15, 2009 | Zenith TVBR1342 13 in. Combo
Cant get my universal remote to work my Zenith model TVBR1922
ha i can help a little ,i also have a rca universal and same tv,vcr combo,the codes in the list rca provides
do not work ,but if you go through the code search procedure componet vcr,until the set turns off
hit enter,this will allow for power on off funtions and ch up down or number keys,also vcr functions,
but no vol, control or menu nevigation,hope this helps a little
Jan 08, 2009 | Zenith TVBR1922 19 in. Combo
Codes for universal remote
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 25, 2008 | RCA Universal Remote Control
Remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
Sep 07, 2007 | Philips Magnavox Learning Universal Remote
Zenith MBR3458T MBR3458T Universal Remote Cable/Vcr/Tv P/N: Mbr Logo
44 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
