Question about BenQ W1000 Home Entertainment Projector Projector
Benq w1000 projector
Benq w1000 runs fine for half an hour and then flickers until picture goes black. lamp used 2700 hours full power
Marrie
  • 563 Answers
SOURCE: Benq MP610 does not project any picture
OK , then this is positively a Mainboard problem.
Check if this unit is still under warranty as the BenQ MP Series came out with a standard 3 year warranty and in which case will cover the replacement of this part.
Posted on Apr 21, 2008
SOURCE: Benq PB8220 lamp used for 375 hrs shuts projector automatically
Unplug any cables from the projector (except for power)
On the device (not the remote control) hold down exit for 3 sec
lamp status are shown
on the remote control use MENU, and then left right to reset lamp
Posted on Oct 01, 2009
  • 35 Answers
SOURCE: Hi, the Benq PB8263 projector is working fine we
Please check the input selection some times it goes to y,pb,r mode.
Mahesh
M.R.Corporation
Mumbai -India
Posted on Aug 05, 2010
  • 11800 Answers
SOURCE: I have a BenQ PB6100
The inverter - the system that generates the high voltage needed by the bulb - has failed due to normal wear. When that happened it has surely done some damage in the power source also.
The projector is fixable, the inverter/ballast board will have to be replaced and the power source tested and repaired if necessary. But on an such old device, age related failures will be common from now on and in the end fixing them will cost you more than a new one - it's time to accept that this one has done its duty and it's time to retire.
Just cut your losses and buy a new one.
Posted on Jan 07, 2011
heathgr
  • 442 Answers
SOURCE: hi re; BENQ W1000 cleaning I opened
please tell me what the POWER, TEMP and LAMP leds are displaying when it finally settles down after the attempt to power on.
Posted on Mar 02, 2011
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 07, 2014 | Office Equipment & Supplies
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
My benq projector turns on for a few minutes (light and fan going strong), then it shuts down.
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Nov 30, 2009 | BenQ Office Equipment & Supplies
Flickering dots on Benq PB6200 projector.
it's not the lamp. if you've replaced the cords and still have the problem, reset the settings to factory default to make sure the resolution matches. if still not ok, there may be an issue with the main board.
Oct 04, 2009 | BenQ PB6200 Multimedia Projector
Benq mp6100
If this problem happen with a particular laptop then I suggest that you you change the setting of the laptop you are using. Go to Start=>Control Panel=>Performance and Maintenance=>Power OPtion=>Power Option Propreties=(click on Hibernation Tab and uncheck Hibernation box).
While on the Power Option check the time on the SYSTEM HIBERNATION.
Good luck
Dec 25, 2007 | BenQ MP610 Multimedia Projector
X1a powers on, then video dies
Check whether the menu comes on the Screen. then check the DMD circuit.
Jun 04, 2007 | InFocus X1A Multimedia Projector
BenQ W1000 Home Entertainment Projector Projector Logo
35 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
