Siemens Siwamat XLM 1162 stops during draining
SOURCE: My Siemens XLM 1200 keeps
I hae a siemens XLM 1200. The clothes are not smelling clean, they smell of stale water.
Posted on Sep 14, 2008
SOURCE: SIEMENS XLM 1600 (WXLM166AGB) MACHINE
If water is being dispensed from both sides of the detergent tray, dismantle washing machine and remove top plate of the detergent tray and clean thoroughly. Water overflows from both sides during the rinse cycle to add softener to the rinse. On our washing machine it was blocked. During the service it was changed but can be washed out to solve problem.
Posted on Sep 15, 2008
  • 190 Answers
SOURCE: SIEMENS XLM 1600 WON'T GO INTO SPIN CYCLE
Dear customer,
                     When the spin cycle doesnt occur the most recommended steps are
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission.
  You can click on the highlighted words to get details abt the checking procedure..
Plz rate this solution.. thank you..
Posted on Apr 09, 2009
  • 13 Answers
SOURCE: Siemens Siwamat c12 manual needed
This site says they have the manual. I see it is not free, no idea how much they charge for manuals etc. Hope that will help you.
http://www.manualsnguides.com/search.php
Posted on Jul 17, 2009
SOURCE: Siemens Siwamat 2105 washing machine leaking
Ater beeing switched on the machine does not fill with water.
Posted on Jun 22, 2010
Please tell me the part no. of Siemens Siwamat 266 timer and where can I find it. Can I get Service Manual for the machine?
https://www.download-geek.com/download/Manual+Instrucciones+Lavadora+Siemens+Siwamat.html?aff.id=9001&aff.subid=100
Sep 08, 2017 | Siemens Washing Machines
My washing machine is leaking a lot of water during a cycle - underneath in the front. Could there possibly by a back log of water? I have drained it, but it's a lot of water.
You will need to open up the front or rear panel and inspect the hoses before and during operation to see where the leak is. There are many Youtube videos on how to remove the panels. Good luck!
May 18, 2016 | Siemens Washing Machines
Siwamat xli1240
Unplug it for a minute, that should reset it, if that does not work, then you need to get a meter to check the heating coil and also the water valves to see if they are ok.
Nov 11, 2013 | Washing Machines
Washing machine not filling up with much water
it could be the water valve is faulty. that would cause the fault.
Jun 17, 2013 | Siemens Washing Machines
My siemens xlm 1400 wont fill with water so when it spins clothes are not cleaned.It won't drain properly either. It sees to only fill 10% of the water required. I have checked the pipes/hoses - a
I would take the back off and look for a small 5mm pipe leading upwards from the base of the drum and take it off and blow gently into it you should hear a click and one when you release the air if so then the place where you took the pipe from is blocked clean it out with a pipe cleaner or metal rod and replace the pipe as sometimes this pipe gets blocked with soap goo preventing the water sensor from doing its job eric
Jan 01, 2018 | Washing Machines
Siemens siwamat 6140
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTMUse the link, you will need to enter the Enr number which is on the rating plate and should start W...
Nov 22, 2011 | Siemens WDi1640 Front Load Washer / Dryer
Jul 17, 2009 | Siemens Washing Machines
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
