Question about Toshiba estudio 255 Copier
Toshiba estudio 255se margins
Network printer. all pages printed are starting lower than they should be. Margins are set properly, user settings are also set properly. It's like the top margin somehow is a half inch lower than it should be, cutting off the bottom of every document printed
4 Suggested Answers
hamzaskilltd
  • 316 Answers
SOURCE: Toshiba EStudio only one half page prints
1) expose lamp moving time half on and half is not on
2 harness bar cable broken
Posted on Aug 15, 2010
gunzzzz
  • 391 Answers
SOURCE: during multiple feeds, the 1st copy is okay, but on the next succeding copies, top margins spacing varies that will cause the bottom copies to be cut
Meikriezl Ulit:
Remove the paper tray and use a "Q-Tip" dipped in alcohol to clean the paper pickup roller and the double-feed prevention pad (below the paper pickup roller.
Posted on Feb 24, 2013
Testimonial: "thanks for the response. ive already tried cleaning the pick up roller. the same problem occurs in every cassette even the by pass feed"
scoutboss
SOURCE: i have problems copying with my toshiba estudio
I had this with mine so programmed the "other" paper size with the one I wanted- in my case A3, code 01. To do this find your manual and follow the steps to programme this button. It's the same as changing the tray size and when "other" comes up type in code. I guessed O1 for A3 as it's not listed. It not works fine on "other" but not on normal. So half job done but at least I can use it. It scans fine.
Posted on Mar 18, 2013
Pt 65 margins
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 20, 2014 | Brother PT-1000 Thermal Label Printer
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Check Your Margins
Select New Margins
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
I can't get my computer to print because it keeps saying the margins of section 1 are set outside the printable area of the page. I have a meeting to go to and It's important that I get this paper off the...
I assume this error is occuring in Microsoft Word.
  1. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  2. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  3. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  4. Click OK.
May 12, 2010 | HP Officejet J5780 All-In-One Printer
THIS IS NOT AN ISSUE WITH MY MARGINS. I have Microsoft word 2007, an HP Officejet Pro 8500 Premier and windows vista. After some research I found a commonality with my problem and these three operating...
The problem may lie in the printers setting for the margins. Do you set the margins only in word 2007 or do you check the printers margins too?
Also the issue may lie with the printer having the incorrect paper size
Have a look in the printer properties (When you go to print, its beside the printer selected) and look through there and see if there are any issues.
Dec 02, 2009 | Toshiba Satellite P205D-S7454 Notebook
I am not able to print the portion from exactly start of the page of ms word document, why? Not able to show it in print preview??
Hello and Welcome to FixYa!
The portion within the Margins can only be printed, lessen the top margin at bit.
I remember the top margin for default is 1', change it to 0.5' or 0.6'
In Office < 2007 (Margins are in File > Page Setup)
In Office 2007 (Margins are in Page Layout > Margins > Set it to Narrow)
Note: If you printer is non-Laser (I mean if it is Ink-Jet) Do not make the margins too less, the printer won't be able to print it.
Sep 27, 2009 | Microsoft Office Word 2007 Upgrade Version...
The printer will not print on the half inch left edge of the page.
go to settings and change the left margin to 0.0. if in Word, then file->page setup and set the margins to what you want, left margin to 0.0 in your case.
Sep 02, 2009 | Laser Office Equipment & Supplies
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
Margins want gone
full bleed, eh? that will be in the print settings issue..make the margins 'nil' and you might get lucky. that's usually a custom print job, by the way.
Feb 06, 2008 | Dell 3110cn Laser Printer
Toshiba estudio 255 Copier Logo
96 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
