Question about Dishwashers
Bosch dishwasher keeps running - Dishwashers
4 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: bosch dishwasher motor keeps running no water
Hola Lewis!
This is such an easy repair, you'll be shocked and surprised! The reason this is happening is that the computer or timer has detected a "flood" condition and has permanently energized the drain pump to clear the "flood".
What you'll need to fix it...
1.) Shop-Vac (for vacuuming water) with a crevice tool (like one of these)
2.) T20 Torx bit with a driver. Torx sizing here. (You can get a set at Home Depot or Lowes)
All you gotta do now is get down on the floor and remove the kick panel. Then remove the screws holding the water valve and lift it up out of its' plastic holding. Now your shop-vac w/ crevice tool can be used. Stick the crevice tool in there (about 10") and vacuum up all the water that's been trapped in the basin. (you may need a flashlight to see what's going on back in there...) After the water is gone, your DW will work fine.
Here's how it works... About 10" behind the inlet valve is a "float" made of styrofoam. When water gets into the basin, the float rises and eventually trips a "flood condition" switch. This switch shuts the unit down and will only allow the drain pump to operate. So what you want to do is get the water out of the basin.
There may be a reason for the basin flooding, though. Suds (caused by too much (or the wrong) detergent), an actual water leak from the valve, etc... So after you get the water out of there and the unit is working again, you may want to monitor it (like, only run it when someone is home) for a while just to make sure that a real flood does not occur.
Hope this helps.
SG
Posted on Mar 23, 2009
  • 98 Answers
SOURCE: Bosch built in dishwasher shu4302uc
There is a recall on the control board of many of these models. I have written a guide to help. It is here. Look for the phone number near the top.
Posted on Jul 19, 2009
  • 98 Answers
There is a recall on the control board of many of these models, butyour problem is likely not related. I have written a guide to help. It is here. Thanks!
I have an integra shx46a that keeps on running and running for several hours and when it completes the dishes are still dirty. I cannot find the directions for the self diagnosis that In know some Bosch...
most bosch dishwashers have a filter that can be removed and cleaned at the bottom of the tub check filter to see if it is dirty. if the filter is clean make sure your water is hot enough min 120 degrees at faucet may want to run hot water at sink before starting dishwasher
May 12, 2011 | Bosch Integra® 500 SHX46A0 Dishwasher
My bosch shx46a05UC/14 will not shut off. I can open the door and the dishwasher just keeps going?
Are you please able to confirm what exactly is happening when you mention "dishwasher just keeps going".
Is it in a wash cycle and throwing the water around through the wash arms or do you just hear a pump running with water sitting in the base. Most likely there is a leak into the base and the auto stop circuit is trying to empty the dishwasher by running the drain pump. I would suggest you check the base of dishwasher for leaks.
Jan 28, 2011 | Bosch 24 in. SHX46A05UC Built-In...
My bosch dishwasher model shu33a keeps running.At first the sanitized light would not light now it just keeps running and when i open the door its not real hot like before..the washer is only 3 years old.
change the control module. check to see if there is a recall on this module. bosch will tell you if it is.give them model # and serial #. by the way if the modell is arecall you will get a free fix. let me know if this info helps,
Feb 23, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
I have bosh dishwasher model shx46 is stak on demo cycle
lol
There is not demo cycle. Most likely your board went out and it just keeps running all the time. (common problem)
Bosch dishwasher repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Bosch Integra® 500 SHX46L Built-in...
Bosch dishwasher motor keeps running no water
Mar 23, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Dishwasher
carry out a reset.
This should reset the board back to factory settings,
Deep Diver
Dec 28, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
13 people viewed this question
Top Dishwashers Experts
