Question about Nordic Track Exercise & Fitness
Want to move a nordictrack C2150 to another room, doors are too narrow
Hi, I have a NordicTrack c900i that I'm moving from one room to another in my home. What can be done to make this fit without harming the treadmill please? Would we remove the "legs", or what and how
can you place a blanket on the floor and tip the unit on it's side and put one end through the door followed by the rest slide it through on the blanket
Feb 07, 2016 | NordicTrack Exercise & Fitness
NordicTrack C900 Pro Won't turn on
Double check:
Chances are that "$%#T Happens" is not your problem. And that if it worked prior to "dis-assembly, it should work after re-assembly". The common denominator is you took it apart & put it back together. So.. something was missed. A wire not connected, a switch not flipped, a wire in the wrong spot, the safety key not in the slot, etc, etc.
Good Luck
Mar 06, 2015 | NordicTrack Exercise & Fitness
Belt not working
I believe your talking about the Controller, not a computer board. This device may turn on, however; the instructions and sequence of activity will not work. Many reasons for this to happen; and usually the problem is traced back to a power surge. Major components and equipment need to be plugged into a UPS (Uninhabitable Power Supply) with special protection to avoid damage to vital electronics. If plugged into the wall (directly) there are no protection devices and current can pass through a device and damage the controll unit.
Mar 25, 2014 | Nordic Track NordicTrack C2150 Treadmill
Nordictrack c2150 panel not working
adjust the Reed SWITCH, see the diagram attached it. Clean it, test it of open or faulty. Tight the connector very well. Replace and clean the contacts batteries( if they have).
Tight the ribbon cable inside.
If the problem persist, after you did, replace control display board
God bless you099b95f6-0273-44db-b9a8-431d1bfaedf5.gif242bb3fe-383b-4bdb-aa92-fe8728465711.gif
Jul 25, 2013 | Exercise & Fitness
How to replace the walking belt on the c2150
see the video and proceed according at your common sense and logically: GOD BLESS YOU
Jul 25, 2012 | Nordic Track NordicTrack C2150 Treadmill
Cant fit it through the door to move to another room.
Only 3 choices:
1 - leave it in place
2 - Take it partially apart so it will fit through the door
3 - Widen the door frame.
Since the treadmill got into the room, it should be able to get out. Most likely #2 is the option for you.
Dec 07, 2010 | Nordic Track NordicTrack A2550 PRO...
I have a NoerdicTrack C1900 about 2003 .......it was in a room and not used. moved it to the garage and it has no power. It was moved on a dolly and was not drop or anything. BUT the room that it was in...
lynda there should be a reset button located some were near the bottom front of the machine try hitting the reset button, it acts as a circuit breaker switch.
Oct 24, 2010 | Nordic Track NordicTrack Professional...
Exercise & Fitness Logo
52 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
