Question about Coffee Makers & Espresso Machines
Message: Please fit the descaling funnel and close the door
Miele 2660
4 Suggested Answers
  • 548 Answers
SOURCE: Miele descaling funnel?
DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinegar. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinegar and run through machine as if making coffee. Repeat this process several times using fresh vinegar until it comes out clear. Do this once a week and your maker will work much better. **************
Use citric acid or LEMON JUICE CONCENTRATE instead of vinegar. It cleans just as well but doesn't leave the funky odor that vinegar does. You can run enough water to get rid of the vinegar taste, but the odor will linger for days or weeks. Much better to use lemon juice concentrate (no pulp!!) or one of the commercial products like the one available from Starbucks.
Posted on Sep 15, 2009
  • 177 Answers
SOURCE: Miele Descaling Funnel, does anyone know what it
hi,
if your model is a recent model which uses capules it is the red plastic bracket which looks nothing like a funnel. it replaces the black bracket as it is called to the left of the carosel.
Hope this helps.
Posted on Apr 15, 2010
  • 70 Answers
SOURCE: miele coffee system CVA 2660 is showing fault #10
F10 is a water intake fault. The are several possibilities: the pump may be defective, a piece of lime scale may have blocked a pipe, the water tank might be faulty. Most likely is the pump.
Posted on Jun 19, 2010
Hi. I need order a descaling funnel for miele CVA 2660. Please let me know how to do it? Thanks. Jim
Page 62 for the instructions Jim
For descaling you should only use the descaling tablets
supplied. These have been specially formulated for use in
this coffee machine. They are available from your Miele
dealer or the Miele Spare Parts Department
Get the funnel there too.
https://www.nespresso.com/ecom/medias/sys_master/public/8842295967774/miele_built-in_user_manual_-_english.pdf
Mar 15, 2017 | Miele Coffee Makers & Espresso Machines
What is a miele cva 2650 descaling funnel
The descaling funnel is a small, dull red insert that replaces the capsule holder and is used during the descaling cycle. I purchased a used CVA2650 that came without the funnel. I called Miele concierge service for help. They stock the descaling funnel and sell it for $15.95. In my case, they simply mailed one at no charge without me even asking. Great customer service!
May 10, 2012 | Miele CVA2650 Stainless Steel Espresso...
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
The machine says to descale _ How do I do that???!!
THIS INSTRUCTIONS ARE FOR THE MIELE CVA 615,
The coffee system must be descaled regularly. The time period depends on
the water hardness set. The appliance will display a reminder message and
will eventually lock if not descaled. The message window will first display:
"DESCALE AFTER COFFEES: 100".
This message will appear until the appliance is descaled or locks. When
the count is down to zero, the appliance will lock and the message
window displays: The appliance can only be used again
once descaling has been performed. Let the machine cool before
descaling. Remove the sleeve of the steam nozzle to avoid damage from
the descaling agent. Only use the enclosed descaling tablets for descaling.
The descaling tablets are specially designed for descaling this coffee
system. Other agents may damage the machine and affect the taste of
the coffee and hot water. The descaling tablets can be purchased
from Miele.
To prevent damage to the exterior of the machine wipe up any descaling
solution spills immediately! Add 2 liters of water to the water tank. Dissolve two of the enclosed
descaling tablets in the water.
^ Close the water tank and insert into position.
^ Close the door. The descaling will take place in the
automatic descaling program.
Automatic descaling
^ Turn the program selector
counterclockwise to the "Program
mode" position.Press e, to select "Descaling" with the asterisk. Press ENTER.
Jan 17, 2011 | Miele Coffee Makers & Espresso Machines
Miele coffee system CVA 2660 is showing fault #10 while I descale and won't let me finish the program. I restart the program by turning off the system but I get the same fault message after about 20...
Jun 17, 2010 | Miele CVA615 Espresso Machine
Miele Descaling Funnel, does anyone know what it looks like?
hi,
Hope this helps.
Apr 14, 2010 | Miele Coffee System
CAN I RESET THE CAPSULE COUNT ON MY MIELE CVA 2660 COFFEE SYSTEM.IT IS SHOWING 3798 -CAN I GET IT RESET TO ZERO ?
No, Not without replacing electronic. You can only reset descale counter in service mode. All other counters are not resettable.
Mar 22, 2010 | Miele CVA2660 Stainless Steel Coffee Maker
How can I override descaling on a Miele coffee maker?
how can i override descaling on miele coffee machine cva 2660
Oct 30, 2009 | Miele CVA2660 Stainless Steel Coffee Maker
Coffee Makers & Espresso Machines Logo
55 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
