Question about Holmes 1.1-Gallon Tabletop Humidifier HWM6008-LUM
I need a manual or advice as to cleaning the unit
How do I clean my Walgreren's 2065 humidifier
Easiest way to explain it is for you to go to walgerrens.com then look for manual or cleaning instrutions/ Basiclly clean the filter by washing and vacuum units coils to remove dust.
Oct 20, 2014 | Humidifiers
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
Wire Honeywell HE220 to N8MPN/L, *8MPN/L furnace control board
HI
I have similar isssue with HE220 but in my case the water run through all ththe time, even when unplugged from the power outlet.
Would that be solenoid issue?
the unit run fine for last season so the wiring is fine.
Any ideas would be greatly appreciated.
Jan 22, 2012 | Honeywell HE220A1019 Whole House...
Our Kenmore 50pt dehumidifer is less than 2 years old, only used for 1 summer, tried to use it last week, it starts/runs but does not withdraw any water, please help. Thanks kindly
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you unit is manual control,
turn the control knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter. Filter should be cleaned once every 2 weeks.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Humidifiers
My Vick's Warm Mist V74A was absolutely lovely when I purchased it (May of June of 2010). However, I CAN ADMIT (because I'm sure majority of people are not) that I have not cleaned it since or read my...
The simplest and easiest way to clean the interior workings of the unit is to fill the tank with a 50/50 solution of White Vinegar and Bottled Distilled Water. Run the unit for an hour. Turn it OFF for 30 minutes and the run it again, until the tank is almost empty and turn the unit OFF. Empty the remaining solution and refill the tank with Bottled Distilled Water. Turn the unit ON and operate it for at least 45 minutes to an hour. This will flush out all of the remaining solution.
What you saw before before cleaning the unit, was a build up of mineral deposits and scale from the tap water that you used. In the future, I would highly recommend that you use Bottle Distilled Water, rather than tap water. That way, you won't have to flush the unit as often and you'll be using water that is mineral free.
Hope this helps you solve the scale and mineral deposit problem. Please don't forget the rate my response to you. Thanks!
Apr 14, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
I have a Vicks V3100 and dont know how to put it together or if I even have a filter. I do not know what the filter looks like
There is a Wicking Filter that is also the same media that creates the humidity. This filter looks like rolled up paper media(like for a swamp cooler). This filter installs at the back of the unit with the water resevoir removed. The water then is absorbed by this media and as the air passes through it humidity is released into the air. The Wicking Filter will need to be replaced when the performance of the unit decreases and the material becomes hard from mineral deposits. There is also a Protec Cleaning Cartridge that looks like a small plastic ball with a stem on it. Inside this cartridge are softening agents that remove hard minerals and extend the life of the Wicking Filter. The Cleaning Cartridge is just simply placed inside the water resevoir. To prolong the life of the Wicking Filter and unit make sure to use clean and cool water. Distilled water will work the best if available. The harder the water you use the more the unit will need cleaning due to hard water. When the unit becomes clogged with diposits you will need to run a solution of vinegar and water through the unit to clean it. If you use distilled or filtered water(reverse osmosis) then the unit will rarely need cleaning.
May 14, 2010 | Vicks V3100 1.2 Gallon Humidifier
How to clean air-o-swiss humidifier?
Gererally according to the booklet in the box.
If you no longer have those instructions, simply clean out the
basin, make sure no mold, dust, hardwater or calcium is deposited.
Use a 10% bleach water solution to kill bacteria, and thats is basically it.
Just dont miss any spots, but humdifiers should be cleaned every few uses.
Feb 19, 2010 | Air-O-Swiss 7133 Humidifier
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
Mar 22, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
Cleaned my Venta VS207 now it won't work. Only flashes.
My unit was doing the same thing as others here and I was able to fix the issue. I believe the issue is that the sensor for the water level, which is located in a tube connecting the two water reservoirs in the main unit, has something blocking the sensor. Most likely this is bacteria growth or other debris which has built up over time. I used Oxy Clean which has some bubbling action and very hot water to clean both sides for about 30 minutes. When I flushed out the reservoir, it started working again.
If take the base off the unit by removing the 4 screws, you will see the "tube" I'm talking about. Since this has what appears to be sensors in it, I didn't want to remove the tube from the bottom to clean it and instead to the approach above. Hope this helps someone.
Jan 16, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Venta 207 digital humidifier
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
Apr 03, 2008 | Venta VS 100 Humidifier
Holmes 1.1-Gallon Tabletop Humidifier HWM6008-LUM Logo
29 people viewed this question
Top Holmes Humidifiers Experts
donshafer
ray gallant
Bill Boyd
Are you a Holmes Humidifier Expert? Answer questions, earn points and help others
