Question about Garden
John deere 176 back fires like its out of time
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
mowerman1857
  • 389 Answers
SOURCE: pto spis all the time on my 1989 john deere 420
Are the blades turning? If they are not, this is normal. The PTO is an electro magnetic clutch that engages when you apply electricity via the PTO switch. When it is disengaged, the bearings and top portion of the clutch will turn because it is coupled to the engine. If the blades ARE turning then you have a bad clutch and will need to repair or replace it
Posted on Sep 18, 2009
nova2nv
  • 197 Answers
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Posted on Nov 14, 2009
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
adamfjeld
  • 1508 Answers
SOURCE: ignition timing on john deere gator 6x4.the motor
wrong forum
Posted on May 16, 2012
Injector pump on 850C John Deere dozer miss firing
You just go to the link I attached I'm sure you will get the solution of your problem.
John Deere dozer 850C
Mar 12, 2016 | John Deere Garden
John deere z225
Either timing is off or you may have turn key off with engine hot and running in high speed. Always return engine to idle for at least 30-45 seconds before turning engine off.
Jul 19, 2014 | John Deere EZtrak Z225 Zero-Turn Riding...
I used my John Deere L110 Lawn Tractor all day yesterday. Turned the engine off, it popped. Then went to start it today and it just pops, seems like the timing is off.
throttle down your engine before turning it off . this reduces amount of fuel going into a hot engine ,just a few seconds before switching key off , should stop back firing issues.
Sep 09, 2013 | John Deere L100 Series
Where is the john deere 4500 fuel cutoff switch located?
the tank might not have one but if is not starting due to fuel check the anti back fire valve on the bottom of the carb they stick all the time causing a no start problem
Apr 26, 2012 | John Deere Garden
What is the correct method to install water pump
Hello. Make sure the metal surfaces are all perfectly clean and sanded smooth with emery cloth. make sure the gaskets fit well. if not trim them. Finally if all else fails use some gasket cement to insure a leak proof water pump. This gasket cement is a common item available at most hardware and auto parts stores. Joe
May 07, 2010 | John Deere Tractor 50, 60, 70, ITJD10
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
