Question about GE lectric Slimline 1Way VHS Rewinder 85201
Top doesn't pop up at end of rewind - GE lectric Slimline 1Way VHS Rewinder 85201
    Sergeant:
  • 458 Answers
Open up the unit and clean the belt to remove the gloss. Use a cloth moist with rubbing alcohol to remove the gloss.
Posted on Feb 27, 2015
Top doesn't pop up (open)
Open up the unit and clean off the belt. Scrub it with a cloth moist with rubbing alcohol. Also clean pulleys.
Feb 07, 2014 | GE lectric Slimline 1Way VHS Rewinder...
Asahi Pentax Spotmatic SP The film rewind button is fully depressed and won't pop out, and the shutter button isn't working.
if the camera is jammed for any reason, then the rewind button will not pop out. on this model it was common that the mirror cock lever at the bottom jumped. in which case the camera will jam up.
remove three screws holding the bottom cover, remove cover. in the middle of the camera is a lever that needs to be latched by pushing it forward. the camera should release and revert to normal usage.
if this is not the case then there may be something jammed in the winding or shutter gears. in which case you would have to remove the top cover and/or front covers.
Aug 10, 2013 | Canon EOS-AE-1 35mm SLR Camera
My film advance lever is stuck. pushed button under camera didn't work
You may have hit the end of the film. Rewind the film back to the spool until the very end gets back in the shell.
If you think you still have unexposed film do the following. Rewind about 1-2 full rotations. Cover the lens using the cap. We're doing this so that step 2.3 will not spoil your last pictures. Take 2 shots (with the lens cover). This time the button at the button should have popped out.
Feb 28, 2011 | Canon EOS-AE-1 35mm SLR Camera
While repairing broken starter rope rewind spring popped out. need instructions to rewind and reinstall. judy
Re winding starter springs is a real black art, and not for the faint hearted, always wear eye protection before attemping this, hook the end of the spring into the cover, now start winding the spring in one coil at a time, keep your thumb on the coils that you have already wound in to stop them popping out, keep winding it in and turning the cover as well to aid you.Eventually you will come to the last centre coil which should just drop in.
Good luck
Feb 15, 2011 | Echo CS330T 14" Bar Length Chain Saw
This is kind of embarassing... i received an old nikon f65, and i don't know how to remove the film properly without burning it...
The film should rewind automatically at the end of the roll. If it doesn't, press the two film-rewind buttons simultaneously for about one second. The film rewind buttons are maked with a red film icon; one is also the exposure compensation button to the right of the LCD control panel, the other is the auto exposure bracketing button to the left of the viewfinder.
Once the film is rewound, turn the power off. Slide the release lever on the left end of the body, and the back should pop open a little.
You can download the manual from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Aug 23, 2010 | Nikon F65 35mm SLR Camera
I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Jun 07, 2009 | Garden
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
May 21, 2009 | Nikon F80 35mm SLR Camera
Rewind!?
If it is an SLR, there is a recessed button on the bottom of the camera that you push, then you flip the little handle out of the supply rear on top and crank clockwise, after the film is rewound and the real spins real easy, lift the supply real with the little handle and the back will pop open.
Feb 05, 2008 | Photography
Pwr cord rewind reel
You have to pop the grey button off for the cord rewind. There is one more screw under there. You have to be very careful, because you can break one of the tabs that hold the button on. In fact, it is almost a garuntee. There are three tabs that stick off the button that hold it in place on the orange hood. There's a long tab about 3/4 inch long on the inside corner of the button you need to be careful of. Good luck!
Jan 08, 2008 | Hoover S1361 Bagged Canister Vacuum
GE lectric Slimline 1Way VHS Rewinder 85201 Logo
766 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
