Question about Hitachi 36UX01S 36" TV
Green yellow red screen
While watching a program the pictures goes to a green yellow red screen
TV picture goese black and white
Check your cables on the back of the TV and cable box. You either have it connected wrong, or they are loose. If you are using red green and blue, make sure that you are tightly in the red green and blue connectors. If you are using yellow white and red, then make sure you don't have the yellow in the green spot.
Mar 20, 2013 | Dell W3706MC 37 in. LCD HDTV
I have a 2 year old LG LCD TV (model 42LG60) and I am having problems with the screen. I turn it on and everything is fine for a few minutes and then the screen goes to red or green lines that are fuzzy....
Not really a solution, sorry, but I've got the very same problem. I haven't noticed the time before tv faults, but nontheless, it greenscreens or like in your case, redscreens as well. I've been told to open the back, which I did to check the status of the capicitors, which I've done. But, the capacitors "seem" fine. No bulging or popped tops. So, I'm at a stand still...not sure what to do at this point. If someone gives you solution, I sure would appreciate your forwarding it on to me. Thanks. Robert
Oct 23, 2011 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
My picture is in green. The convergence seems to work just fine. Why would my screen be green?
You might have the yellow for video, white, and red for audio (composite connection) plugged into the component plugs green, blue, red for video, white, and red for audio (component connection) somehow combined together on the back of your TV to whatever source your watching.
It should be color to color from your source to your TV.
It's that or only the green plug is plugged in for the component video. Hope this helps.
Jun 20, 2011 | Zenith R57W46 57" Rear Projection...
I hooked up the cords exactly as picture and when in dvd input the picture is in black and white. I tried movie the yellow video chord to every single hole on the back of my tv and it doesnt go to color??...
If you tried the yellow composite cable "in every single hole" it wasn't exactly 'exactly' following the manual then, was it?
Are you using component cabels, too (red, green and blue). Mis-wiring them will give you B/W or other wierd visuals.
Your TV's inputs and what is selected by the TV's controls would determine which cables' input it display. You could prove whether the composite is the culprit by removing it while viewing the TV. If the picture goes away, THAT cable is carrying the video you're watching. Otherwise, maybe you need to select the component input and check the conenction of each wire while watching.
Mar 18, 2011 | Bose 3·2·1 II System
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
Ps3 powered down suddenly. It won't power up. green,yellow, red
if i where you i would send it to sony they are the only ones that can help you..
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
Picture keeps turning green or yellow
This could be the screen amp board or a picture tube shorting.
$$$ yes
Jul 11, 2008 | Sony KP-57WS520 57" Rear Projection...
Picture is yellow
Your picture tubes are weak or you need to do whats called a grey scale adjustment. In other words you need to put on a totally B&W movie or test pattern and adjust the red , green, and the blue screens to the best B&W you can get. Then you need to adjust the CRT drives to the best grey scale. If you do not know what this is, I'm afraid you should call out a pro to assist you with this alignment, as if you go messing around, and do not know what you are doing, you can make the set landfill material. Not for a novice to do. Good Luck
Sep 13, 2007 | JVC AV-56WP74 56" Rear Projection...
Maxent 42' Plasma sound but picture looks like red, green and whites digital specks
the color card in the plasma is not okay.ihad the same problem and fixed it.
Apr 25, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 36UX01S 36" TV Logo
13 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
