Question about Baumatic BWE40 Wine Cooler
Can I keep the light on, baumatic glass fronted wine cooler
2 Suggested Answers
  • 2427 Answers
SOURCE: Baumatic BW18 wine cooler; at
the soft humming your hearing could possibly be the compressor stalling.. this can come from a lack or freon. Now this is the first thing you should check as its one of the most common issues in all refrigerant systems.. to do this there is a check port that you connect a guage too and it will give the freon pressure. More than likely you will find it very low and needs re gassing.. before having it regassed I'd suggest that you have it checked for leaks as well ,, (it ran out of freon rather quickly no ??) have a technician come in and check these as he will have all the right tools and stuff needed for for the checking of gas pressure, the dye to check for leaks as well as the freon to regas it.. and if needed the solder to fix any leaks..
Posted on Sep 17, 2010
BWE40 wine cooler. Is it safe to leave it switched on when code e2 is showing? Does code e2 distinguish which of the two sensors need replacing? Thanks.
Hi All,
I had this error on my wine cooler. I checked the sensors and got a reading Kohm from both, however i still decided to replace the rear sensor - buried in the foam. It is located in the foam about 20cm from the LHS and 20cm from the bottom of the foam.
I got the sensors from here https://www.inter-spares.co.uk/?subcats=Y&status=A&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&search_performed=Y&q=49032008&dispatch=products.search
I left the front (internal sensor) and just swapped the two terminals in the 4 way plug. I used normal expanding foam to fill the areas where i had removed the foam looking for the sensor. All up and running now.
May 11, 2014 | Baumatic BWE40 Wine Cooler
How can I achieve the best aging out of my wine cooler?
You should look for a cooler with a UV-tinted glass to minimize the UV effect on the wine quality. The most important thing you have to remember is to keep the temperature level as stable as possible (around 55 Fahrenheit).
Aug 14, 2012 | Furniture
Where can I find wine cooler for picnics?
There are so many of them, but I recommend getting one that can hold more than one bottle. Even if you do not want to take 2 bottles of wine, you can always get real wine glasses and store them on the other bottle space. it will keep the grasses from braking. Try this one: http://www.amazon.co.uk/i-koncepts-CB2NBH-Luxury-Picnic-Cooler/dp/B0006VHTH0
May 29, 2012 | Furniture
Hello, I have BW40 wine cooler. On the display is blinking error message "E2". I have tried to switch off and switch on, but it doesn't helped. Thanks for you support in advance. br, Zoltan
There are 2 sensors in this wine cooler. Malfunction of each leads to E1 or E2 fault codes. One is easily accessible inside the fridge (small white torpedo sensor with pair of wires attached). The second but identical sensor is buried within the foam on the rear of the cooler. Unplug from mains, take of the electrics from back of cooler, take off sheet metal back and the sensor will be deep in the foam and can be replaced easily after digging out some foam. When replaced make sure the sensor is in the same place it stops the cooler icing up. Use gap-fill foam to keep insulation good. Dr_Nicholas
Sep 28, 2010 | Baumatic BWE40 Wine Cooler
Can you cool bottle beer as well as wine
yes...beer will be fine in the cooler
Jan 03, 2010 | Baumatic BW18 Wine Cooler
Haier BC112G wine coere is an apparent spill that
you will have to gently pry it all around with a thin scraper, i am assuming there is no sealer as fluid would not have leaked in if there was.be gentle but forceful.
Oct 17, 2009 | Haier BC112G Wine Cooler
Magic chef wine cooler
That means couple of things. The cooler's glass door is poorly insulated, and the cooler is placed in a humid environment. To eliminate the sweating you can run a dehumidifier close to the cooler, or you can insulate the inside of the door with styrofoam but that's going to spoil the look of the cooler.
Aug 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Code E2 showing in temparature display
I contacted the technical team at www.baumatic.co.uk and here is the reply I got.
-----Original Message-----
From: Samantha.Codd@baumatic.co.uk [mailto:Samantha.Codd@baumatic.co.uk] On Behalf Of Technical@baumatic.co.uk
Sent: 25 January 2008 13:02
To: Taline Bedrossian
Subject: Re: BWE40 wine cooler
Good Morning.
Thank you for your e-mail.
This error code means that your appliance has experienced a defrost sensor
fault. Please contact our service team on 01189 336 911 to arrange a
suitable time for an Engineer to visit you.
Kind Regards
Quality and Technical Department
Baumatic Ltd
www.baumatic.co.uk
Jan 19, 2008 | Baumatic BWE40 Wine Cooler
AVANTI WC40D
it is replace able but if you get the new door is better for you.
Dec 25, 2007 | Avanti EWC28 Wine Cooler
Baumatic BWE40 Wine Cooler Logo
19 people viewed this question
Top Baumatic Refrigerators Experts
Sal DeAngelo
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
