Question about Zebra QL 420 Plus Thermal Label Printer
Front panel menus are gone I think this happened after I used Setup Utilities vs (i have always used label vista) but changed over when we upgraded to Win7
2 Suggested Answers
  • 254 Answers
SOURCE: Our thermal label printer Zebra
That means that your settings are wrong or the commands are not transmitted.
You are probably in inline mode try to switch to page mode
Posted on Aug 16, 2011
What setting label do I use for Chromecast on Proscan HDTV PLEDV2845A
You must download the chrome app to your phone and access using google chrome browser.
Feb 18, 2015 | Proscan Televison & Video
Cannot connect to printer anymore
make sure you have the current drivers for this printer are loaded. and select the wired set up configuration type. go to control panel select printers and see if the printer is visable to your pc. if not start over and reconfigure a new printer. and
follow the prompts. and may i also suggest going to there web site and check for the latest and the greatest on your model.
Apr 09, 2017 | Zebra QL 420 Thermal Label Printer
I have a Ribbon In Warning but I don't know how to change to Thermal Transfer on Driver. where do I do this? Can't find on menu on front panel
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences" Choose the "Advanced Setup" tab Change media type to "Thermal Transfer" Be sure that "use printer settings" is NOT selected at the top left Click OK and you should be good. Note that any labels created prior to this change will need to be changed inside each label under the label setup.
Jun 16, 2011 | Zebra S4M Thermal Label Printer
Changed the ribbon, but the labels are to light.
The DARKNESS setting controls the amount of ink released to the label. The 105 has a range of 1-30, 1 is the lightest - 30 is the darkest. The setting used will depend on the combination of label / ribbon used. There is no "correct" number, always try to use the lowest setting with acceptable print quality.
The DARKNESS can be adjusted from the front panel by pressing SETUP and changing or DARKNESS can be controlled from the software or printer driver. The printer driver or software usually overrides the setting in the printer.
Hope that helps !
May 07, 2010 | Zebra 105SL Thermal Label Printer
Hi Name is Joe.
Resolution
Installing on a Windows Vista computer
Creator 2010 requires a minimum of Windows Vista Service Pack 1 for installation. You can either perform a Windows Update (recommended) or install Service Pack 1 for Vista here.
Installing on a Windows 7 computer
The issue might be caused by the Creator 2010 setup package running in Windows Vista compatibility mode on Windows 7. Please use the following steps to turn off Vista compatibility mode for the Creator 2010 setup package:
  1. Right-click on the setup package and choose Properties.
  2. Click on the Compatibility tab in the Properties window.
  3. In the Compatibility mode section, uncheck the box that is labeled Run the program in compatibility mode for Windows Vista.
  4. Click OK to save the changes.
  5. Re-run Creator 2010 the setup package.
May 04, 2010 | Roxio Creator 2010 Full Version for PC...
I bought a computer and was given a free upgrade with it, i have not yet used the disc but i have just found that I need to purchase a separate upgrade license, please advise
If you are talking about the MS Windows upgrade offer, I believe the offer was only temporary... If you are going from XP to Vista - you could always try calling MS and ask for a new Key - they may provide you one for free... now that Window's 7 is out - they may be thinking you are upgrading to it!
Oct 06, 2009 | Computers & Internet
When I try and connect the HP wireless upgrade printing kit it doesn't recognise the adapter and so won't procede. Any ideas?
you do not need an upgrade kit.....this printer is a wireless printer.....so can use it wirelessly without any upgrade kits.....just need to run the wireless setup wi\zard on the printer from the front panel menus and then nyou have to install the s/w using the disc that came along with the printer and you need to select the connctivity as wireless and then follow the on screen instructions...
Mar 27, 2009 | HP Photosmart C7280 Printer
I purchased some 16X dvd-r & dvd+R discs
Instead of using Roxio, which is problematic anyway (it's just part of the manufacturers bundle that comes with some new pcs and it doesn't always work correctly, it seems to cause conflicts with the system's own copy utilities - I always uninstall it) ------- just use your system's burn/copy utilities.
Mar 01, 2009 | Computers & Internet
Preamp/Processor missing menus/options for DTS
Solved the recognition of DTS signal issue but the DTS options/settings in the menus are still not appearing - believe the previous owner may have upgraded the software. The solution for the DTS signal recognition was an output setting on the DVD (blu-ray) player - digital output vs analog.
Jan 27, 2009 | NAD Audio Players & Recorders
SRA3 printout is not same size but slightly smaller
Try this!
Phaser 7300 Printer: Turn metric defaults on using the printer's front panel
The Printer's Configuration Page will show that Tray (1-5) is loaded with Tabloid Extra instead of SRA3. To have the image scaled to SRA3 instead of Tabloid Extra, turn On Metric Defaults at the Printer's Front Panel.
You can switch Metric Defaults On or Off at the Printer's Front Panel as follows:
  1. With Menus highlighted, press the OK button.
  2. Select the Printer Setup Menu by pressing the Down or Up Arrow button.
  3. Press the OK button.
  4. Select the Reset Printer Setup Menu by pressing the Down or Up Arrow button.
  5. Press the OK button.
  6. Select Metric Defaults by pressing the Down or Up Arrow button.
  7. Select On or Off by pressing the OK button.
Dec 29, 2008 | Xerox Phaser 7300DN Laser Printer
Zebra QL 420 Plus Thermal Label Printer Logo
26 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
