Question about Epson GT-1500 Flatbed Scanner
Document feed stopped working - Epson GT-1500 Flatbed Scanner
Printer will not advance to tear after print
I can't give the exact solution for this printer, however, I use the Epson POS thermal printer and here was our solution. In Windows 7 go to Devices and Printers. Click on Printer Properties. Then see if you see a tab that says Document Settings. Under that setting click on Paper Source. You should now see several options; I have mine set on Document(Feed, No Cut). There are other options but we prefer to tear ours off. You can chose Document(Feed, Cut) and it should advance then cut the paper for you.
Jul 10, 2014 | Datamax E-Class E-4205A Direct Thermal...
Adf is not working
You might have paper stuck in the ADF. Check the ADF by doing the following: try using it for copies and see where it stops. If it stops at the very beginning it might mean bad feed rollers. Take out your feed rollers and clean them with rubbing alcohol and then dry them. If it stops deeper in the document feeder then there is either a paper clip or ripped paper blocking its path.
ADF AND COPIER PARTS AND SUPPLIES
Sep 13, 2012 | Office Equipment & Supplies
Document in ADF
None of these worked for me. Here is my FIX:
Open the part containing the rollers. You can see a white plastic part which stop the documents feeded into the adf. Lower this part and insert a page into the adf just a bit further than where it would have stopped from that white stopper. This forces the machine to feed the document and clears the error right away. You only have to do this once and from then mine worked fine.
Jan 25, 2012 | Canon Pixma MX410 All-In-One Printer
The HP Laserjet 3050 in our office does not feed the document through, it tries but you can just hear it turning. The printer contantly reads "document loaded" without anything in it. After a...
I haqve an all-in-one that I had problems with the automatic document feed quite frequently with. If you can get to the feed rollers that **** the pages in fairly easily, it is often a simple matter of cleaning these rollers with alcohol and a cotton swab thoroughly. They are often spongey so if you use water they will not dry easily, I cleaned mine on my HP G85 and it works like new now. I couldn't beleive the solution was so simple but believe me, this worked for me.
Mar 28, 2011 | HP LaserJet 3050 All-In-One Printer
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Document feeder
Am not sure but,it looks like problem with static charge building creating the problem.See that the document path grounding is ok
Oct 25, 2008 | Office Equipment & Supplies
Documents not feeding
There is usually a switch sensor lever in the area where paper is loaded into the document feeder area(near the document feed roller check to see if its not stuck or damaged
Jan 31, 2008 | Sharp AL 1631 Copier
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Epson GT-1500 Flatbed Scanner Logo
50 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
