Question about HP Photosmart C6280 Printer
Enter special key combo - HP Photosmart C6280 Printer
4 Suggested Answers
  • 30 Answers
SOURCE: HP 3210 Ink System Failure error code 0xc18a0307.
I have the HP Photosmart 3210 All-In-One with this stupid ERROR 0xc18a0307. I didnt purchase this printer, my uncle gave it to me and told me how much it was worth. That was enough to motivate me to try and fix it. Im not an IT guy or computer geek..probably just lucky...Maybe it was this "L.A Confidential Kush" weed!!! : D
My uncle gave this printer to me w/o the yellow cartridge so i went to Best Buy and bought HP Photo Value Pack for like $40. Before i did the steps mentioned below, I pretty much did everything that you could find as a troubleshoot process and it failed. I then decided to remove the cartridges and open up the ***ing printer and tried to get to the sprayers so that i could use the CRC Mass Air Flow cleaner ( I spent 6.99 for it at Auto Zone. as a last resort.)When i noticed how complicated everything was getting ( it totally killed my high!! ) I said **** it and re-assembled the damn machine. Before I started putting everything back i noticed that the white plastic spocket was off of the metal hex plug that is connected on the left side ( if you are facing the front of the printer while its taken apart ) so i placed it back on carefully and continued the re-assembly ( i dont know if this was the cause of the ERROR 0xc18a0307, but previous suggestions mentioned that it might be a mechanism failure.) After I was done putting everything together I put the cartridges back, plugged in the power cable from the back of the printer first, and then i connected it to the power outlet. I then connected the USB cable to the back of the printer but i forgot to plug in the USB to the CPU ( as mentioned below ) Then i did this ****....
( and i did this with everything connected except the USB cable, only because i forgot it was disco'd from CPU )
1. Put all the cartridges back into the printer. ( only if you didnt already do it after reading my story )
2. Press and hold down the four buttons at the same time:
OK, Cancel, Black, Color while the printer is off.
3. Then you hit the POWER button ONCE and then hold it AFTER it blinks or turns on and release the four buttons. DONT LET GO OF THE POWER BUTTON!!
( it might show that its resetting but i dont remember )
4. hold it for a full minute or until the copy button turns on
( i dont know what happened first because i was stoned and i started thinking about what i was going to do first if this stupid sequence worked, >8 D )
5. The copy button will light up and you will get a menu that asks your preferences.
6. Go thru the preference selection and then when your done hit the copy button with something you could copy in the scanner. Select number of copies and It should start to copy if the process worked. ( you will see the display in the cool little screen that says " Copying...." if not, try it over and over. you might find another way to fix YOUR problem.
Then i printed a doc from my computer and it worked.
After that, I scanned something to my computer and it worked.This is all i was able to try since i dont have a landline!!
I wish everyone luck with thier HP Photosmart 3210xi All-In-One!!
Posted on May 24, 2009
  • 73 Answers
SOURCE: After replacing color cartridges I get the
try pressing buttons in sequence blue then green then grey it should take you to a special menu look for reset meni and select semi full reset if that does not work try removing the cartridges while machine on pull out power cord wait 15 seconds plug power back in insert cartridge when promted on display screen
Posted on Jan 26, 2010
Rider On Way
  • 1679 Answers
SOURCE: Having difficulty getting my HP photosmart 3310 to
There are several special key combo for ex. 1-2-4 and 3-2-9 also 1-2-7 depending on the purpose of using it.
My suggestion would be,
Remove the cartridges,
Clean the golden ( electrical contacts ) with lint free cloth
Put the cartridges back and check if the error message disappears
If not,
Try the Full reset following these steps
Disconnect the power cord from back of printer ( while printer is on )
While holding the # and 6 button, connect the cord
( if you do this reset, the printer will loose all the memory it has stored like fax logs, will get disconnected from Wireless network )
The error message is likely due to a cartridge expiry date and certain printers do not accept such expired cartridges from present date. Try replacing such cartridge
Posted on Oct 12, 2010
What is the Special Key Combo
•"print photo" + "red eye removal" buttons pressed together
•printer will not ask you to enter the combo
•release the buttons you pressed then
•press "red eye", "print photo", "red eye" in sequence
•scroll down or right until you find resets menu
•press ok
•scroll down or right until you find semi-full reset
•press ok
•your printer should turn off, wait for 3 minutes before turning the printer back on
(i may represent HP but this advice is solely my own)
Feb 03, 2015 | HP EPPSC5280PHOTOTRAYAS PhotoSmart C5280...
Hp touchpad is froze up
On many laptops, there is a soft switch to turn the touchpad on and off. It is a keyboard combo of the Fn key and one of the special function keys. The special function key will have a picture of a touchpad on it. Press that combo and see if function is restored.
Dec 27, 2011 | HP DC170B Keyboard
No click or enter response thru the touchpad.
Sounds like your touchpad may be turned off or possibly it has gone bad. In the former instance, check to see if you have turned it off. Many laptops have switches on the keyboard (may be a combo of the Fn key and a special function key). In the latter instance, you need to get the computer repaired.
Feb 13, 2011 | Computers & Internet
Having difficulty getting my HP photosmart 3310 to print! Tried all the suggested reset options etc. even was able to get to the 'OVM reset', however, I'm still getting an ink failure msg... and when I...
If not,
Oct 12, 2010 | HP Photosmart 3310 Printer
After replacing color cartridges I get the following message on my C6830 HP printer ''Enter special key combo''
Jan 26, 2010 | HP Office Equipment & Supplies
I have a HP 3300 photosmart printer, have an error code that says 0xc18a0507?? i cant print or anything..
Try doing a reset by holding down the * and Menu/Enter keys while plugging in the unit, hold the keys down until the screen says that it is resetting.
The 3300 also has a "Secret Menu" that can be accessed by;
To View The Secret Menu:
1: Press Both The Left And Right Navigation Arrow Keys
2: It Will Ask You To "Enter A Special Key Combo.", Enter "123" (Without Quotes)
3: You Should Be In The Secret Menu Now.
P.S. Use The Arrow Keys To Navigate.
The manual can be found at;
http://www.fixyourownprinter.com/reference/manuals/public/hp
Hope this helps!
Dec 09, 2009 | HP LaserJet 3300 All-In-One Printer
HP Photosmart C6280
I have the same problem with the HP C5180 won't go no further and is now a brick! Any suggestions? Never had it working at all
Jan 12, 2008 | Computers & Internet
HP Photosmart C6280 Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
