Question about Hotpoint Refrigerators
Shelves exfl181op how to just frige shelves
I need a manuel for an Amana refrigerator model AAF2534FEW
Double check your model number that number appears to be incorrect
Appliance 911 Sea Breeze
Sep 28, 2015 | Amana Refrigerators
I need new shelves for my whirlpool fridge as they are cracked. Where can I find them. I live in Melbourne south east. And does anyone know the approximate costs? Thanks
I use www.apddepot.com . you can look your barnd / with model # and get parts brake down . and part # of what you want . and prices . and order from the web also .. they are very good and fast .. **** hope this will help . in order to look up these for you i would need your mod # as all friges are different . mm
Jan 05, 2010 | Refrigerators
I have water pooling inside the refriderator. It
there is a drain in the freezer than gets pluged, unplug frige from wall, put food in ice chest take hair dryer and melt ice thats at back wall in freezer remove icemaker if there, and back wall of freezer inside, melt any remaining ice, **** up water with wet vac or sponge,see the pinky size hole in the pan under the coils, point hair dryer at it for a wile. now take the the lower back cover off behind frige and blow all the dust out and find the plastic tube, about the size of your finger and put the wet vac on it until you can hear it sucking in the freezer, take e cup of hot soapy water ond poor it in the freezer pan. put everthing back and your good to go
Dec 09, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Frige door won't close all the way. No pressure on door
Make sure there is nothing on the shelves protruding in the vicinity of the bars on the door.
I have seen this to be the problem on a number of service calls.
It could possibly be in the lower door hinge too. A bad or loose cam can cause the door not to close.
Nov 12, 2009 | Samsung RS2630SH Side by Side Refrigerator
The freezer drainage
you have a clogged defrost drain, remove the bottom basket, and freezer shelves to expose the screws for the back panel remove back panel,carefully chip away ice, and or use boiling water to melt the ice from the drain hose, check complete drainage by removing back panel behind frige at bottom and inspect that the water is draining completely into defrost pan. reoplace all parts.
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator is not cooling like it should
we had the same problem turn it off for 24 hours ice build up in the back makes this happen
Jun 16, 2009 | Maytag MZD2766GES Side by Side...
Frige is running but blowing warm air in freezer and frige running but not cooling. just blowing air like a regular fan. the air is not cold at all even after i left it running for a long time.
theres not really any solution if its short of gas you would need to buy the gas and gauges which would be a lot more expensive if you knew an engineer that would do it outside work hours you could get it done a lot cheaper which might keep you goin for a while but if its short of gas there is more than likely a leak somewhere and if its not fixed it will end up costing you more money in the long run
Apr 13, 2009 | Frigidaire Gallery Series GLRT13TEB 30"...
Water leak
My frige was doing the same thing. The drain plug was frozen. Try checking your drain plug, which is located behind the panel on the back side of the unit.
Mar 30, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
KENMORE SIDE BY SIDE NOT COOLING
You should hear a fan running inside the freezer. It also blows cold air into the refrigerator side.
Jun 09, 2008 | Kenmore 50522 / 50524 Side by Side...
Open Questions:
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
