Hanimex slide projector manual
I have a hanimex rondette 1800, slides keep getting stuck and i dont know how to get them out. Help.
3 Suggested Answers
  • 412 Answers
SOURCE: Automatic slide changer is stuck in
The problem is continuous cycle (like you don't know that already...). It indicates that an adjustment to the cycle contact is necessary. To open the projector, first unplug it and remove the lamp module from the rear of the projector. Turn the projector upside down. Remove the 6 - T15 TORX screws from the bottom (5 around the perimeter and one in the channel next to the cord wrap). CAREFULLY pull the bottom off (the power wires connect the bottom cover & top together!!). Once you have it open, leave the projector upside down, put on your safety glasses & plug the projector into the wall. At the center of the projector you should see a hub rotating about every second or so. Above it you should see a "J"-shaped wire. See the attached illustration.
You will have to, in repeated steps, unplug the projector, bend the "J"-shaped wire GENTLY & SLIGHTLY, plug the projector back in and cycle it a few times. Check for the position of the "J"-shaped wire to the pad, and GENTLY repeat until you achieve the position shown in the illustration.
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: All slides are fuzzy on
If it is fair to make the assumption that the projector focussed slides correctly in the past,m then here are my suggestions:
- More than likely there is probably one of the optical components missing or out of position.
- The other thing that could be affecting focus is that the projector is too close to the screen, I would open the compartment where the optical components are located and check for proper position and cleanliness.
Good Luck !! jim
Posted on Dec 12, 2011
45 year old Slide projector
Ask around your local photo shops for a guy with a long grey beard to ask.
You could try advertising for an instruction book on your local freecycle and if Hanimex is still in business they might help you.
Some of those slide projectors were intuitive as they were completely manual but there were also magazine load, semi-auto and fully automatic versions that could also have a recorded commentary and backing music synchronised to the slide show.
Best of luck friend, have lots of fun with it.
Sep 04, 2015 | Office Equipment & Supplies
Is it possible to take apart & clean a Hanimex 72-162mm lens? If so, how?
Is it possible yes, is it recommended no. Lenses are full of little tiny precise parts that are difficult to assemble. The smuges you see are probably mildew. This will eat into the coating on the lens. Hanimex was a an importer based in Australia. They did not manufacture lenses themselves. I have used many legacy lenses on Olympus cameras, Hanimex and others. As a general rule I found these lenses did OK as a macro but only average in general use.
Sep 22, 2014 | Cameras
Where can I find a replacement bulb (24V 150 W Q.I. type Hanimex Type A1/216) for a vivitar slide projector.
Try searching at www.bulbman.com or at a "Batteries plus Bulbs" franchise. Look on the lamp for a 3-letter code. This ANSI code is unique to the lamp and is a great aid in lamp identification.
Mar 14, 2013 | Vivitar Office Equipment & Supplies
Slide magazine to fit prinzauto
Hi these Prinz slide projectors are made by the same Australian company who makes the Hanimex brand ,they use both the 120 rotary mags and the 36 or 46 slide trays,the Prinz brand are made for the British market,ive bought a great Prinz concord auto still in its orginal box,where about do you live?
Jun 26, 2012 | Office Equipment & Supplies
All slides are fuzzy on my hanimex Rondette 1500 RF
Good Luck !! jim
Apr 18, 2011 | Vivitar V5000AF Slide Projector
Where in Canada can I obtain bulbs for a Vivitar 2000AF slide projecter 24 volt 150w Q.I ( hanimex type A1/216
Try www.Bulbman.com. They have an amazing assortment of discontinued lamps! Good Luck !!
Feb 13, 2011 | Vivitar V5000AF Slide Projector
I have Hanimex Rondex 120 rotary magazines. I was told these would work in the Vivitar 5000AF. Is this true, as the slide on mine is jamming on the return?
I have a VIVITAR 5000 AF slide projector.
Occasionally, the slide gets stuck while operating the mechanical hand to change the slide. Most of the time it works when I push the slide carrier by hand. Very very infrequently, the projector actually throws out the slide.
I have ascertained that teh Kodak slides which are mounted on paper frames are much too thin for the mechanical hand pushing teh slide in and out. The solution is to remount teh slides on palstic frames or some how add to the thickness of the slide. I have not tried it yet , though.
Any more ideas?
MNAQUVI@yahoo.com
Jan 23, 2011 | Vivitar V5000AF Slide Projector
Cd stuck in cd changer
You could take the radio out and take it apart, but you would still have an $1800 CD. Suggest forgetting about the CD, and getting an aftermarket installed for much less.
Mar 07, 2009 | 2005 Suzuki Aerio SX
202 people viewed this question
k24674
jasbo
jasbo
