Question about Mesh Computers & Internet
Not connecting mesh matrix 2400 will not connect to the internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
More information is required.
are you using ethernet or wireless?
Posted on Jul 10, 2014
3 Suggested Answers
dante777
  • 623 Answers
SOURCE: dell dimension 2400, wireless internet
Hi Whitney,
I was able to locate manual and a troubleshooting guide.
  1. Manual
  2. Troubleshooting Guide
Summary: Your modem only supports 802.11b standard, which limits the throughput to max. 11Mbps (compare to 802.11g = 54Mbps, 802.11n = 108 Mbps). In other words: your connection is only about 10% of the speed compared to a wired connection via Ethernet cable (100 Mbps). So - if you can - you should try to use a wired instead of a wireless connection, but you have to decide what makes is more important to you: having no cable and you can be away from the modem or the connection speed.
This also means - and that is in regards to APremkumar's solution - that you can skip all 802.11n adapters (this would just be a waste of money). Since you will not find an adapter that only connects to a class b network, look for something like "802.11b/g".
An example page is here. You can choose between an internal (PCI card) or external (USB adapter) solution. Both are ok and the decision depends on the availablity of a free USB port on your Dell and your comfort of opening the computer case or not. (You can always come back here and ask for help;-)
If you have any more questions, please let me know - I'm happy to help!
Posted on Mar 31, 2009
  • 47 Answers
SOURCE: i can't connect my dell dimension 2400 pc dt to
Check it in the Device MGR see if it is working ok then update driver or completely uninstall it and Restart and it will find and reinstall it ! If you have the dell disk put the driver disk in and reinstall it from disk. Hope this helps!
Posted on Nov 19, 2009
How do I connect my Matrix m1 mobile phone to the internet?
How to Use the Pantech Matrix for the Internet1.Press the "Menu" key on your Pantech Matrix and click "Settings.
2.Click "Connections" and highlight "Modem Link." Press the "OK" key. Turn the modem link settings to "Inactive." Press the "End" key to exit to the phone's standby screen. 3.Download and install ActiveSync on your computer if the operating system is Windows XP. If you have a later version, download and install Windows Mobile Device Center. Follow the on-screen prompts to properly set up the program. 4. Press the "Menu" key on the Matrix and click "Settings." Scroll down to "Connection" and press the "OK" key. Click "USB" to "PC." 5. Open ActiveSync or Windows Mobile Device Center. Click "Device Settings." Click "Internet Sharing" under the "Programs" tab of the program. 6.Select "USB" from the drop-down menu under "PC Connection." Select "AT&T" from the "Network Connection" drop-down menu. 7.Click "Connect" and connect the Matrix to the computer using a USB cable. A status message of "Connected" will appear in the program's window when the connection is established.
Jul 21, 2011 | Pantech Matrix Cell Phone
Plugged dell 2400 into phone line without broadband but it will not connect to the internet
You can not connect broadband ( 10/100 Base Ethernet connection ) to a phone line. The input jacks are different size.
Mar 27, 2011 | Dell Dimension 2400 PC Desktop
Dial up connection ok but wireless will not open explorer Dell computer 2000XP Eircom connection
The dial up connection may be corrupt
delete the dial all the existing dial up connections from
internet explorer>Tools>internet options>Connections>
remove existing dial connections in Dial up and virtual private network settings
add a new dial up conection and set it up again
It show be up and running
Feb 11, 2010 | Dell Dimension 2400 PC Desktop
Cant get on the internet
The longer the cable, the slower the connection.
It should work with the cable as it is not "too" long.
I would try turning the modem and router off for one minute and then turning back on.
Jennifer
Dec 29, 2009 | Dell Dimension 2400 PC Desktop
I can't connect my dell dimension 2400 pc dt to the internet, it says that it is reading the connection but it won't connect
Nov 19, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400, wireless internet
Hi Whitney,
  1. Manual
Mar 30, 2009 | Dell Dimension 2400 PC Desktop
Dell inspiron 2400 wont connect to the internet etc.
First You need to get the chipset driver, video driver to correct resolution and network drivers. Check in hardware manager which device need a driver and install it.
Mar 07, 2009 | Dell Dimension 2400 PC Desktop
Internet hard to connect
what is the intrent like 56k cable if it pulgs into ur phone line u might need to go get a better card if it lan that should be like 10/100
Nov 30, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop - Can't connect to internet
The NIC (network interface card) is integrated into the motherboard of the 2400 computer. Most likely that circuit is bad. To fix it you’ll have to replace the motherboard or purchase a NIC card and install it into one of the PCI slots on the motherboard.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 16, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
18 people viewed this question
Top Mesh Computers & Internet Experts
David Payne
David Payne
Are you a Mesh Computer and Internet Expert? Answer questions, earn points and help others
