Question about LG LFX21980ST Stainless Steel Bottom Freezer French Door Refrigerator
Er ff the erff code is coming i need to know where the freezer fan is.
You need to remove the freezer door and basket. then remove the rails on both sides. then there is a panel at the back of the freezer. Pull at the top part of the panel and it will come out.
Posted on May 23, 2014
SOURCE: lg lrfd22850sw frige code says ER FF. what does it mean! Please HELP!!!
I had the same error code. The problem was that the fan had frozen. I defrosted the fridge/freezer completely (it was ok for me cause I have a spare fridge). Your problem possibly is a frozen fan problem
Posted on Jun 26, 2008
SOURCE: LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Posted on Apr 08, 2009
  • 363 Answers
SOURCE: fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Posted on Jul 26, 2009
jan mczeal
  • 632 Answers
SOURCE: error code er ff.how do i fix this?
The error code appears when there is an abnormality of BLDC FAN Motor for Freezer. It circulates cold air from the freezer to the fridge to allow cooling. Check the motor wiring harness for poor connections. If the motor is not working at all, you need to replace it.
To remove the fan and motor assembly:
  1. Remove the freezer shelf. (If your refrigerator has an
    icemaker, remove the icemaker first).
  2. Remove the plastic guide for slides on left side by
    unscrewing phillips head screws.
  3. Remove the grille by removing one screw and pulling the
    grille forward.
  4. Remove the Fan Motor assembly by loosening 2 screws
    and disassembling the shroud.
  5. Pull out the fan and separate the Fan Motor and Bracket.
  6. Replace fan motor assembly in reverse order.
Posted on Oct 27, 2009
Testimonial: "thanks, that made it a lot easier"
I did this and it worked great (so far - 3 days now...). It took me a while to figure out, so here are some tips.
The panel is inside the freezer, the back wall. You should take off the door, the ice maker, all the shelves and the left rail to get it out. It will then lift up and pull forward.
I removed 3 bolts on either side of the door to remove it -- not sure if that's best/easiest, but it worked fine.
You need to remove all the shelves and the center piece that drops from the freezer ceiling and sits on 2 metal rails -- it provides the slider for the shelf on the right. Lift it up from the two metal rails and slide the bottom to the right to dislodge it. The top just fits into a depression in the ceiling of the freezer and the bottom has notches that line up with the metal rails. The metal rails pop up -- just lever a bit with a slotted screw driver on one end.
There are 3 phillips head screws that hold the left rail (whatever the thing is that the door slides on). Remove those and pull away from the wall and forward. There are two tabs at the back of the rail that will pull free with a tug.
The ice maker has 2 screws on top, one below and is plugged in. You only need loosen the top screws, then remove the bottom one and pull the plug free (which was kind of hard). The plug is in an insert in the back panel and I just left it in place and removed the insert from the back panel using a slotted screw driver in the small gaps around the edges. Lift the ice maker up and off the top screws and it's out.
There's one screw holding the middle of the back panel on -- remove that and pull up and forward to remove the panel. Make your cut and reverse all this and you're good to go.
Posted on Jan 02, 2010
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
Kenmore model7957160 error code erff
ER FF is a Error Message that your Freezer Fan is not working properly, W10128551 Evaporator Fan Motor The problem could be your=> 2169142 Fan Blade has become damaged either by ice or loose fan motor mounts. Someone will need to unplug and remove the rear panel of freezer to observe just what has taken place, Thanks Sea Breeze
Feb 17, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator displaying error "ER FF".
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The door panel says "Er FF" and now it is not cooling
Er FF - Freezer Fan Error - This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Oct 30, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Error code ER FF
code for defective freezer fan motor. ER FF
Sep 21, 2009 | LG LFX25960ST Stainless Steel French Door...
Hi, On my LG LRFD25850ST I am getting an error
er-ff is freezer fan error not running,check for ice build up around fan,a know issue.if ice build up a new main board will be needed.or just a bad fan..
Jun 20, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Er FF ON THE BORD
FF usually means the freezer fan is not working. If the fridge is cooling poorly, check to see if the fan inside is running while the compressor is running. If not, and if there's no ice jamming it, then you need a new evaporator fan. If the fridge is cooling normally and the only symptom is the error code, then it could be a problem in the electronic control.
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG LFX21980ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
46 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
