Question about HP OfficeJet G85 All-In-One InkJet Printer
G85 printer problem. None of the buttons on the panel work.
None of the buttons on the front panel work
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
Vista driver for hp g85
Uninstall current driver (if any) before installing the new software from HP support: (choose your OS)
HP OfficeJet G85 Downloads
Jan 08, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
My Officejet G85 does not from a document
Ensure it is installed (use the driver CD) and set it as the default printer in Control Panel > Printers.
Jul 08, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
HP officejet g85 doesn't scan to Word 2003
This has nothing to do with Microsoft Office.
unistall the printer from start>>control panel>> add and remove program.
reinstall the printer software, and connect the printer by following the on screen pormpt.
Jan 11, 2009 | HP LaserJet 1020 Printer
Officejet G85 printer
If you previously were using a parallel connection for the G85 you will need a USB cable.
If your laptop is running Vista the G85 will work as a printer, I do not think there is a scanner driver for Vista for the G85. The G85 print driver is built into VIsta, you only need to turn on the printer and install the USB to have the printer automatically installed.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Not printing none of the troubleshooting solutions is working
Have you tried shutting down the spooler temporarily, then restarting. Works for mine, on occasions when certain printing jobs seem to freeze the printer.
Apr 01, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Fax rings but will not pick up or give fax tone
hmmm..that's a fax settings issue on the front panel...you may new drivers for that hp.
get them here
Feb 28, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Hp printer
ok...first thing...go to www.hp.com and download a fresh set of drivers for your printer, and then restart it and see if that helps. I have that happen to my G85 whenever the power gets awful(not saying that's your reason, but can be an issue)..
got backup?
Feb 15, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
