Question about HP OfficeJet G85 All-In-One InkJet Printer
G85 printer problem. None of the buttons on the panel work. Open front door nothing happens and Front panel displays the word "Initializing" continually.
Buttons on front panel do not work. Open top to copy no light or sound. Open front door nothing happens.
SOURCE: hp officejet 5510 all in one cartridge error
There are several different ways I've come across which will resolve ink cartridge errors on the HP Officejet 5510.
HP's standard, pat answer to the problem is "Buy brand new genuine HP ink cartridges." If you refill your own ink cartridge or have it done at Walmart or somewhere else, you will eventually run into this problem. Why? Because the 5510 stores information on as many as 2 of the black ink & 2 of the color ink cartridges you have used in the machine - complete with an "expiration" date for each of those cartridges. You can refill them, but unless you clear the stored memory in the printer you probably won't be able to get around the errors. Even if you do, they usually come back in a short period of time. I know this because I own a 5510 & a 5110 and have battled this problem myself for a couple of years.
Short of buying "genuine new HP ink cartridges", using your printer for target practice, or testing it's aerodynamic design... lofting it not-so-gently from a 2nd-story (or higher) window... aiming for the nearest dumpster ;) you might try:
  • http://www.misterinkjet.com/hpreset.htm Scroll down and you will find links to pages for the #56 & #57 cartridge serial number reset procedure.
  • If the above doesn't resolve your problem, try removing both cartridges, then - with the printer still turned "ON", unplug the power supply cord from the back of the machine. After one minute has passed, press down and hold both the "#" button and the "6" button on the keypad and while pressing those buttons, reach back and plug the power cord back into the machine. The LED readout will indicate "Initializing" and "Reset..." Then, release the "#" and "6" buttons and wait until the machine re-initializes and prompts you to install ink cartridges. Reinstall the cartridges and see if the problem is resolved. The reset procedure, as well as other troubleshooting procedures (paper jams, ink cartridge jams, etc.) can be found here, on the HP support pages.
  • Another way of working around the cartridge error problem is to keep at least 3 sets of cartridges on hand, using the newest sets for re-filling. You may have to switch out 2 or 3 times just to get the machine's memory maxed out, but the third set should work. This particular method works best with OEM HP cartridges, but I've heard it works with other brands, too.
For more adventurous-techie-types, who can't resist tearing into the machine in an effort to resolve the cartridge error permanently, I found the following information posted on a DIY (Do It Yourself) repair forum:
The 5510 has a pair of 1.5v batteries which function much like the CMOS battery on the motherboard of your computer - they supply power to the memory chips which store the serial numbers and expiration dates of the last 2 sets of ink cartridges which were used. The batteries are sealed together at the top and bottom and are attached to a circut board inside the printer on the left-hand side. At a glance, they look a lot like a capacitor or something like that attached to the board. If you look closely, you will see the "+" and "-" markings.
Breaking the connection (located at the top) between these two batteries will clear the ink cartridge serial number info from the printer's memory - but be advised this will probably also clear other short-term memory items also - such as last number redial, etc.
The clever individual who posted this info actually attached wires - one to the top of each of the 1.5v batteries - and ran the wires out through the opening above the paper trays. The wire-ends are connected together - I imagine they would need to be held out of the way of the paper path with a piece of tape.
(M-I-C-K-E-Y...M-O-U-S-E) He, he
When it's time for a cartridge change/refill, the wires are disconnected to clear the memory, then reconnected again after the full cartridges have been installed.
I've read posts from people with different models of printers have mentioned installing a switch to clear the memory - a preferable solution than to have wires running out from the inside of your printer.
This is a widespread issue and regardless of how you resolve the error messages, one must always remember that when you bypass something that is built-into the design of an electronic device, you run the risk of damaging components. In this case, the biggest problem would be running too low or completely out of ink and burning out the print head on the ink cartridge; then you would end up having to replace the cartridge anyway.
Personally, I'm basically fed up with the way HP has been forcing people who buy their printers and All-In-Ones to pay outrageous prices for replacement cartridges, by building machines which generate error messages and reject refilled and non-OEM cartridges. Their drivers and software programs often have compatibility problems even with other HP products which are installed on the same computer with an HP printer. Too many problems for me - I won't be buying any more HP printers and I hear Dell is not much better.
While I haven't tried to jump out the memory on my 5510 yet, that will be my last and final effort before giving it the aerodynamics test... into the nearest dumpster!
Posted on Mar 17, 2008
rakeshpramod
  • 234 Answers
SOURCE: copying problem in HP 5610 officejet all in one.
Take out both the ink cartridges from the All-In-One.
Unplug the power cable from the All-In-One when there is still power in the unit.
Also unplug the power cord from the wall outlet end.
Leave it unplugged for at least 1Mins time.
Clean the metal contacts in the ink cartridge as well as the the inside of the All-In-One with a lint free cloth a little water (It should only be moistened with water not soaked) and make sure you will not touch the metal contacts with your hands.
Insert the ink cartridges back to the printer make sure they are not wet.
And connect the power cord directly to wall outlet without the surg protector.
And before connecting it to the All-In-One press and hold the # and No 6 Button in the All-In-One and insert the power cord without releasing the keys untill it comes up with a message as semiful reset or if the screen goes blank then release the keys and turn the power on.
And if it prints a test page it is fine.
Now try and make a copy and check.
Good Luck
Posted on Sep 08, 2008
sanjay_tech
  • 20 Answers
SOURCE: When I press the scan button nothing happens!
For scanning a documnet to  computer the scan button is used. So for scan function to work  properly, the software that came along with the printer needs to be installed in the computer.
Posted on Jan 22, 2009
  • 214 Answers
SOURCE: HP printer doesn't work after clearing a paper jam
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If youu don't find anything you may need to disassemble the printer to find it. What have you got to loose?
Posted on May 16, 2009
SOURCE: HP309C
We have a new wireless network. How do I change the wieless network that my HP 309c is using to print?
Posted on Sep 30, 2010
How do I reset xerox 3045
Try this:
1. To reset the NVRAM (this holds the control panel settings), turn off the printer.
2. Press and hold the On Line (0) and Enter (4) buttons, and turn on the printer. Keep the On Line (0) and Enter (4) buttons depressed until the message "Initializing...Please Wait" appears on display (this takes about one minute).
3. Release the On Line (0) and Enter (4) buttons and wait for the front panel to display "Ready." This takes about 45 seconds.
4. Press the Menu Up (1) button until the Reset Menu is displayed.
5. Press the Item Up (2) button until Factory Defaults is displayed.
6. Press the Value Up (3) button to display the choices. To actually reset the factory defaults you would select "Yes."
Aug 03, 2016 | Xerox WorkCentre 3045ni Multifunction...
None of the buttons on front panel works. I pressed each one but nothing is happening. I just got this through ebay.
Turn the power button on. It should light the switch. Turn it on from standby, it should light up the front panel. Then the switches should work.....unless one of the buttons got pushed in during shipping and it is still stuck in the pressed position. Check that all the switches push back when pressed.
Mar 18, 2010 | Harman Multimedia AVR-354 Receiver
Drawer error
on the diplay panel at the very bottom of the left hand side do you see a small little symblos (wrench) touch it the panel will go to a different display, then once there open and close the front door. its reset procedure. Next try, Open the front door youshould see a cover with a small screw, or if the cover is off, you will see two buttons, one is trouble reset the other is initialize the one to (try 1st) the left the trouble reset to the right, two draws down worked with minolta never had both draws go, make sure once the draws open check behind them for paper. Open and close front door first off also
Aug 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
Paper Jam - HP G85 Ink Jet Printer
You open the door from the back of the printer (turn the knobs) and the paper can be removed from the back. After removing paper jam, replace the door. It is a long door as wide and the printer, but about 2 1/2" wide.
Feb 28, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
HP G85 is stuck on "Initializing"
Sounds like your main board has gone out on this unit. We can sell you a replacment board for $45 if interested. Its not too terribly hard to install.
Inkworks
866-381-0541
Nov 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Replace Transfer Roller
In the Phaser 6250 Color Laser Printer Service Manual (which I had to have emailed to me from my toner supplier since it is not available to the general public) I went to Chapter 6 - Error Messages and Codes. I had to reboot the printer. Here is the procedure.
Entering by rebooting the printer:
1. Turn the printer power OFF
2. Hold down the Back and Information buttons simutaneously and turn the printer
back on.
3. Continue to hold the buttons until the following message is displayed on the front
panel: Service Diagnostics V#.##, Initializing ....., and then release the buttons.
4. The front panel displays the Service Diagnostics Menu.
On the display is a menu. Find Transfer Roller. Press enter on this menu where it says Toner Waste (Not Full). Back out of the menu.
All of a sudden the machine came to life. You may have to turn off the printer and turn it back on again.
Good Luck
Jun 10, 2008 | Xerox Phaser 6250 Laser Printer
Drum light flash Brother HL 2070N
You need to have the front of the printer open, when you press and hold the 'Go' button. All four lights will come on, in sequence. Release the button, and close the front cover. Done...
Feb 27, 2008 | Brother HL-2040 Laser Printer
Hp 1350 all-in-one
When power is applied to the all-in-one for the first time, the power light is solid and the check paper, check print cartridge, black copy, and color copy lights flash, the display will be blank, and the all-in-one will not respond. One or more of the following symptoms will also be observed: The all-in-one keeps turning off Cannot print, scan, or copy The print carriage will not move Windows plug and play (device detection) does not occur The all-in-one does not respond when buttons are pressed, including the power button. SOLUTION: This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one. The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem: Disconnect the power cord. Lift the scanner lid and carefully line up and install the front panel overlay. Plug the power cord in. The print cartridge access door must be closed before the all-in-one is plugged in for the first time. The all-in-one cannot complete its first initialization until the door is closed. Follow the steps below to correct the problem: Disconnect the power cord. Locate and close the print cartridge access door. CAUSE: The all-in-one initializes when it is plugged in for the first time. While initializing, the all-in-one scans a bar code on the under side of the front panel cover requiring that the front panel cover be in place and that the scanner be operable. The scanner cannot operate when the cartridge access door is open On light (green) - On Check Paper light (amber) - Blink Simultaneously Check Print Cartridge light (amber) - Blink Simultaneously Black copy area backlight (green)- Blink Simultaneously Color copy area backlight (green) - Blink Simultaneously Issue Front panel overlay is not attached at all or not attached properly Solution Turn Off the all-in-one. Attach front panel overlay as instructed on Setup Poster. Turn On the all-in-one.
Sep 06, 2007 | HP PSC 1350 All-In-One Thermal Printer
Front Panel Display is Blank - only small black squares
the front panel display initializing and then disapear and then the functional buttoms begin to flash. nothing happen again. when i press the on buttom the same thing reocurre
Jan 06, 2007 | HP PSC 2210 All-In-One InkJet Printer
Sony CDX M8800 Front Panel Problem
u need 2 replace the ribbon that goes to the panel to the unit.i had the same problem with mine then i went on to ebay and found the ribbon there (cdx-m8800 repair kit)hope this helps
Dec 17, 2006 | Sony CDX-M8800 CD Player
HP OfficeJet G85 All-In-One InkJet Printer Logo
13 people viewed this question
Seeker5211
Seeker5211
