Question about MGE UPS Galaxy 3000 UPS System
Cooling fault - MGE UPS Galaxy 3000 UPS System
2002 kia sad on a keeps overheating and already replaced thermostat
Many things besides a defective thermostat can cause engines to overheat. Among them are , low coolant, defective cooling fans or cooling fan circuit faults, and also internal engine issues such as blown head gaskets or cracked cylinder head.Water pump could also be a fault but less likely than other issues.
Anything that is related to the cooling system can be at fault.
You may want to have it diagnosed by a professional.
Feb 23, 2015 | Kia Cars & Trucks
Fan comes on when switch ignition on instead of when hot Tazz
If the fan not turning on when car engine getting hot,then car will notice overheating.Click this link below for troubleshooting:---http://technoanswers.blogspot.in/2012/02/car-running-hot.html--------To know how engine cooling system works ,click the link below :----Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works? http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
------------How to Replace Engine cooling Fan:-- http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
-----------Replace Fan Relay but still Radiator cooling fans not working? http://schematicsdiagram.blogspot.com/2011/12/replace-fan-relay-but-still-radiator.html
----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
---------Where Is Radiator Fan relay and Fuse Located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radiator-fan-relay-and-fuse.html
This will help.
Thanks.
Feb 09, 2012 | Cars & Trucks
When there is a fault with the back to base security system it knocks out the heating/cooling control panel, even though now I have 2 control panels - 1 for heating 1 for cooling.How can the system be
this has appeared under truck and cars try the correct heading to post this question in please and perhaps someone will see it then and not a old washed mechanic like myself
Dec 30, 2011 | Cars & Trucks
Code po560
You will find all Diagnostic Code details available at http://ww.bluejag.co.uk .
This code P0560
Fault Code:- P0560 Indicates a Power-train fault
The fault is generally due to a problem in the Vehicle Speed & Idle Control area
Fault Description: Battery power supply voltage malfunction Note: This DTC can be flagged due to fuel injection pressure sensor fault. If P0193 is also flagged, correct first.
Action of ECM:- none
After clearing the DTC, complete the Engine temperature cool (cooling fans not running) Remove ignition key for 20 seconds (cooling fans not running) Ignition key in, position II for 5 seconds (do not start) Repeat cycle two additional times
Check for a reoccurrence of fault DTC.
Possible Fault:- ECM battery power supply open circuit, high resistance
Jun 18, 2011 | 2002 Jaguar X-Type
My 2003 Hyundai Matrix appears to be overheating but cools down when the internal heating system is turned on full. Is this the water pump failing?
not sure here without getting it hot and running my hands over the rad to see if its hot around the edges and cool in the centre where the fan is as this will signify a chocked up radiator but if its cooling with the heater on full blow then i would suspect a cooling fan fault ,as a water pump plastic impeller fault would not push the water through the heater matrix ,Also i dont think this vehicle has the plastic impeller but a metal one if my memory serves me correctly ,check the cooling fan electrics as iam sure this is a temperature switch fault
Mar 12, 2011 | 2003 Hyundai Accent
I have a 4 year old Samsung side by side fridge and the freezer works just fine, but the fridge side won't cool anymore. We have the digital temp set at 38 and it shows its at 65 degrees and getting...
Hi and welcome to FixYa. I am Kelly
Press the Power Cool and the Power Freeze buttons for 8 seconds it will enter the diagnostic mode.
Take a look at this link to determine what fault you have under
Step One diagnostics..
http://www.ukwhitegoods.co.uk/modules.php?name=Content&pa=showpage&pid=209
There are 13 different faults than can be displayed. Each one of the LEDs in the picture under step one indicate what that fault is by the DIGIT position of the flashing LED. (Legend to the left of picture) Usually that fault is either a component or wiring problem.
The diagnostic test should pinpoint the problem.
Note that the Power Cool and Power Freeze buttons are depressed for 8 seconds to clear any faults. It the fault remains it will reappear again.
Thanks for choosing FixYa.
Kelly
Sep 26, 2010 | Samsung Refrigerators
Cooling fan fault and AC fault
Cooling fan Fault - your big fan at the radiator is bad (open hood & see if its running- if not turn off car immediately) & that trips A/C warning. You need a mechanic as a computer chip controls that.
Aug 09, 2010 | 1987 Cadillac Allante
What is code #code p1296
Definition of Diagnostic Trouble Code P1296 Audi: Cooling system malfunction Chrysler: No 5 volts to MAP sensor Dodge: No 5 volts to MAP sensor Ford: Injector Multiple Faults - Bank 2 Jeep: No 5 volts to MAP sensor Lincoln: Injector Multiple Faults - Bank 2 Mazda: Injector Multiple Faults - Bank 2 Mercury: Injector Multiple Faults - Bank 2 Mitsubishi: MAP Sensor 5-Volt Supply Fault Volkswagen: Cooling system malfunction
Jun 08, 2010 | Volkswagen Jetta Cars & Trucks
MGE UPS Galaxy 3000 UPS System Logo
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
