Question about Frigidaire Ovens
Ultraline gas ranges
Could not hear gas flow control valve turns round and round with no stop position
    Top Expert:
  • 5,922 Answers
Bad valve
Posted on Oct 08, 2017
3 Suggested Answers
mgprice
  • 744 Answers
SOURCE: Oven keeps clicking presumebly trying to light.
Hello, your problem is going to be 1 of 2 problems, 1st did you spill liquid on the switch? if so the switch has shorted out, unplug the appliance for 24 hours to dry the switch out then plug it back in...if after 24 hours it is still clicking you have a bad switch (these are the burner knobs) check each one with a ohms meter, the one that is bad will read infinate on your ohms meter when it is switched off. If you have any other questions please feel free to comment. Good Luck!! Mike
Posted on Sep 22, 2009
  • 46 Answers
SOURCE: We have a Whirlpool Gas
Whirlpool had some grounding issues with some of their electronic ignition ranges. Make sure your outlet is grounded first. Then you might need to make sure the bake burner itself is grounded very good against the range frame. I have put star washers between the burner and frame and tightened very tight, that sometimes helps. Also make sure the holes in the burner under the spark electrode are clear from debris. Sometimes the burning of gas leaves a residue that can stop up the holes and not let the gas flow out where the spark is hitting the burner. Hope that helps.
Posted on Aug 29, 2011
Testimonial: "very helpful, thank you for your time"
Mod# xfg374lvq stove: Both the oven and the broiler will ignite, but only stay on for a few seconds. It does not try to reignite. Is this the control module?
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
The oven sensor: works with the oven control board to regulate the oven temperature. If there is an oven temperature problem, this sensor might be defective. The sensor can be tested by using an ohm meter. As temperature rises, the resistance measurement also rises. The manufacturer of the oven sensor determines the correct resistance, Oven temperature problems can be caused by other things, but this is one of the common causes.
Beware on some models now most of these ovens they are electronic and they are integrated into the control itself
some different sensor ohm readings at room temp. approx 16 ohms at room temperature and at 350?F it is 29~33 ohms.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start Oven Won Turn on
Oct 09, 2013 | Whirlpool Ovens
Turned oven on to 350. the igniter got red but did not heat up the oven.
Good Morning Jim, I understand that your gas range is inoperable. Let's try reprogramming the unit by either flipping the household circuit breaker off or unplugging it. While the unit is turn OFF; confirm that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. Then you may turn the appliance on. If the steps do not correct the issue, your range could be experiencing a communication error with the EOC (electronic oven control), a potential wiring failure, faulty bake or broiler element or power supply. I would personally contact a professional to accurately diagnose the appliance to determine the root cause to reduce the risk of unnecessary parts. If you do not know a professional technician, manufacturer websites often have service provider locators' onsite to assist you in that regard. If you have any additional questions, please feel free to reconnect!
Aug 21, 2013 | Frigidaire FGB24L2A Gas Single Oven
Power surge now our Frigidaire gas range oven does not work
Good Afternoon Wendes, thank you for your inquiry. I understand that your gas range is inoperable. Let's try reprogramming the unit by either flipping the household circuit breaker off or unplugging it. While the unit is turn off; confirm that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. Then you may turn the appliance on. If the steps do not correct the issue, your range could be experiencing a communication error with the EOC (electronic oven control), a potential wiring failure, element or faulty power supply. I would personally contact a professional to accurately diagnose the appliance to determine the root cause to reduce the risk of unnecessary parts. If you do not know a professional technician, manufacturer websites often have service provider locators' onsite to assist you in that regard. If you have any additional questions, please feel free to reconnect!
Aug 04, 2013 | Frigidaire Ovens
No gas to the burner or oven
Hello deodatramdin - If both the range and oven are not working, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. While the unit is turn off, confirm that the shut off valve on the gas pressure regulator is in the "ON" position (typically located on the back left-hand side of the range). This valve shuts the gas off to the oven. Once you have verified, turn the range back on. If it proves to be ineffective, then the range could possibly be experiencing an issue with the EOC, wiring failure or faulty power supply. Contact a certified technician to move forward accurately and to assist with the repairs.
Jan 30, 2013 | Frigidaire FGB24S5A Gas Single Oven
We have a Whirlpool Gas Range, model SF357PEKQ. When I start the bake feature, you can hear the gas flow, the ignitor click (about 4 times) yet there is no ignition of the gas (flame doesn't start)....
Aug 29, 2011 | Ovens
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
MY BROIL ELEMENT WON'T IGNITE ON MY MGS5870ADW MATAG GAS RANGE AND I DON'T KNOW WHAT PART TO ORDER. BACK ELEMENT OR IGNITER IS GLOWING RED.
It could be that the ignitor is weak and only partially heating which could be causing the gas control valve not to open and allowing the gas to flow into the broiler burner tube.
I would also suggest you see if you can smell gas to confirm that the gas supply valve is actually opening up. With the oven door closed, turn on the broiler and after 20-30 seconds of having the ignitor glowing red, turn off the broiler control and open the door and see if you can smell gas, if not it could be either a weak ignitor or a faulty gas control valve.
I would suggest that before you start ordering parts, you swap out the oven ignitor with the broiler ignitor to verify that the broiler ignitor is the problem. It could also be the broiler tube has a blockage of some sort possibly from cooking debris, that is preventing gas from flowing into the tube.
Here's a diagram for your unit along with the parts list.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MGS5870ADW&productCategoryId=0124250&brandId=3048&modelName=MAYTAG-COOKING&diagramPageId=00005&componentDescription=GAS%20CONTROLS&documentId=M0412019&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this very helpful and best regards!
Aug 07, 2009 | Ovens
Electronic ignition works, but the gas does not come on
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
Jun 26, 2009 | Frigidare FGB24S5DC Gas Single Oven
Oven working no gas to range
Check to make sure that you are getting gas to the unit itself. If you are getting gas to the unit from the shut off valve. Then your problem would be the gas valve will need to be replaced. This is the only thing that would not let the gas flow to the unit itsef
Jun 03, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
High flames in oven
Flame saftey device control valve stuck in open position that why main gas is coming other wise flame should be max 2cm long after flame saftey device heat up and bellow expand and main valve should open
Jul 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
