Question about KitchenAid KHWS01PMT Front Load Washer
KitchenAid Ensemble KHWS01PMT3 door latch stuck closed with door still open?
Door lock sticking, so sprayed with lube and accidentally pushed lock to closed position with door still open... cannot get latch back to it's open position.
Krazytech
  • 725 Answers
SOURCE: washer model khws01pmt3 gets Fdl
The FDL error is a door lock issue... I have had many on these errors that would not go away by just changing out the door locks all I have had to change the microcomputer (control) ... most of them are followed by a F11... if it still under warrranty call for service and have them change out both...
Posted on Jun 05, 2008
SOURCE: dishwasher door latch
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Posted on Dec 06, 2008
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Posted on Jan 16, 2009
  • 3 Answers
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Posted on Feb 15, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Kitchen Aid Front Load Washer Model #KHWS01PMT1 flashes code DL
Your Door switch is faulty or, out of adjustment
Posted on Jun 09, 2009
My driver side door won't close in privia van
Check door latch point on your door. It maybe in closed position. Take a small screw driver or needle nose pliars and open latch. After you open latche then spray with a dry lubrcant such as graphite or wd 40 spray. Also lube locking latch on car frame
Sep 20, 2015 | Cars & Trucks
Door locked and will not unlock and cant shut door
sounds like the door latch mechanism is stuck in the closed position. if you pull on the door handle and use something like a screw driver and pull the latch claws open the door should work. the latch is the part that closes around the door striker plate bolt to keep the door closed. lube the latch to help keep it from sticking again.
Sep 04, 2014 | Honda Accord Cars & Trucks
2006tdifordfocusdoors
They are stuck and need to be lubed. Use WD 40 and spray the latch on the door. Then close the door and open it a few times to work the spray in. Then spray it again it should work just fine.
Nov 25, 2012 | Cars & Trucks
Door ajar switch for location and to check it. It act like the drivers door. the warning sign is lite and the mirror light won't go out.
door ajar switch in the door latch, they sometime get stuck ,if you try spraying some lube into the latch and open and close the door a couple of time some times they will un-stick otherwise you will need to replace entire latch.
Mar 01, 2011 | 2002 Ford Taurus
My drivers side door doesn't close all the way because the lock in the door only latches about half way..It will stay closed going down the road,, BUT it's not latched or closed tight.
sounds like the latch is broken or the latch catch is out of alignment. you can try and spray some teflon or silicone based lube on the latch and see if it is just sticking -- some lube goes along way on moving parts. also make sure the door is lining up proper and not hitting anywhere on the frame.
but I would try the lube first,, and then look into possibly replacing the latch.
c...
Feb 02, 2011 | 1995 Plymouth Voyager
Its cold and the door was frozen stuck. But after unlocking it, I pried it open and when I got in the drivers seat to close the door. The latch is stuck in the down position and the door wont close or...
spray the latch catch with oil or silicone to loosen the latch mechanism than stick something [a screwdriver/ pen ] that u can use to push the catch upward to open push on catch while lifting handle if catch falls back either latch spring still frozen or latch spring broken and needs replacement
Jan 11, 2011 | GMC Yukon XL Cars & Trucks
I have a 2006 Saturn Vue. The front passenger
there is a spring inside the door lock that makes it work this spring is most likely broken try spraying lubricant on the lock just in case its binding ,but it seems like you will have to replace the lock mechanism
Feb 07, 2010 | 2006 Saturn Vue
Rear door lock is stuck, cannot close door 1993 jeep larado
you probably nee d a new door latch assembly; inside the door, take alot of wd40, lube the door latch were it closes against striker pin, to free the movable part of the latch; push in on the door handle (like your opening the door), at the same time use a pointy screwdriver awl or flat blade scredriver and push the latch up and out of the locked position, its the movable part in the door latch, hopefully its not bent and will not move. also sometimes the door hinges wear out and the latch striker does not line up with the door latch pin, see if they line up if they do not close the door while lifting it at the same time. I hope this helps you
Sep 17, 2009 | 1993 Jeep Grand Cherokee
Rear door stuck on 1997 Pathfinder...Have
go inside, lift on handle, then beat the **** out of the door pounding it like your trapped in it trying to get out. latch mechanism is probably corroded and froze shut. once open, spray with wd40 and work the lever a lot. then get door panel off to see if handle is broken inside
Jun 16, 2009 | Nissan Pathfinder Cars & Trucks
Doors won't close
Stick a screw driver in where it would normally wrap around striker at door, pull handle and it should flip open there to allow closing. When working properly, it should snap back on its own when handle pulled so I'd give it lots of lube to see if it will start working properly.
Jun 01, 2009 | 1995 Oldsmobile Cutlass Supreme
KitchenAid KHWS01PMT Front Load Washer Logo
67 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
