Fax When fax comes through i can't read the text. It also has two black lines down the left side of the page. I have put a new ink cartridge in the fax machine over a week ago and i still have the same problem. I have tried the copier and i have the same problem. Please help!!!!!!! Thank you.
  • Anonymous Dec 07, 2007
    Black vertical lines on left wide of outgoing faxes sent by our Work Centre Pro 580 fax machine. TEST faxes sent to another machine in the office receive clean copies except for those from our 580 (2001version). What to do? jd
  • 4,889 Answers
Its quite possible the area that scans the paper(s) you are sending is dirty.
If the machine is one of those phone/fax/scanner/copier jobs, simply open the top panel, and with a damp cloth, wipe the runners that feed the paper through from left to right or right to left (just make sure any dirt you're wiping goes off to one side)
its also possible that a paper (that white-out was used on) that has been recently faxed, left some white out on the feeders
Posted on Oct 26, 2007
When fax comes through paper is blank. I've tried 2 different cartridges
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink
cartridge appears in the display, replace the print cartridge. The part number for
replacement cartridges is HP 701.
1. Take out a cartridge from its packaging and carefully remove the tape covering the
printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper
area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
1 Access Cartridge
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
Care and maintenance 45
3. Open the control panel and cartridge compartment cover (it will click and remain
open).
4. Push the cartridge down and remove it.
5. To load the cartridge insert the cartridge as shown below. When the cartridge is
pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks
into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this
step.
1 Control panel
2 Cartridge compartment
cover
46 Care and maintenance
Clear jammed documents and paper
6. Close the cartridge compartment cover and control panel.
7. Press Start/Enter.
8. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the
correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount
of remaining ink. Once you have put in a new cartridge, use it until it is completely
exhausted.
Nov 11, 2011 | HP 640 Inkjet Fax Machine
When i copy or fax get a black ink line down the page
Do you get a black line when printing also ? If not the **** glass the "reads your document has something on it (like whiteout). Lift the cover where you feed documents in and take a look for a small clear plastic window that runs from left to right and clean it with alcohol. Good luck !
Jan 30, 2011 | HP Office Equipment & Supplies
We have an old 9920 PB fax machine and it is no longer under warranty and when our fax receipts come out they have ink on both sides of the paper. I mean extra black toner. Not coming out clear. how much...
Your toner cartridge is leaking because all of then now are refills.
If you decide to put $200 into it for a new cartridge, remove the swinging shield that covers the drum before installing it.
it will come loose and cause paper jams.
Dec 02, 2009 | Pitney Bowes 9920 Plain Paper Fax
Black lines down the side on the fax
hmmm...can you try clean the carrier and cartridge nozzles of your cartridge ..
first open the front cover of your printer in order to reach the carrier and cartridge then clean the carrier by a wet cloth and wipe also the cartridge nozzles on a clean wet cloth .
thanks.
pls rate if it work.
Nov 30, 2009 | Office Equipment & Supplies
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Black stripe down one side of every fax
On my Brother fax machine, there is a blue plastic cleaning thingy on the toner cartridge used to clean the metalic wire. If you leave it on the wrong side after cleaning, you get a thin black strip down the edge of every page. Slide it over to the other side and problem goes away.
Jul 08, 2008 | Ricoh 3310LE Plain Paper Laser Fax
Bad copies
take out toner cartridge shake from left to right and reinstall cartridge
Jan 23, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Fax mach 1800c brother
Although you may not use the other colours the cleaning assembly cleans all the cartridges hence the other ink gets used. To trick the machine into thinking there is ink in the cartridge, place some black tape over the top of each cartridge facing front of the machine. This fools the sensor into seeing no reflected light and reads that there is ink in the cartridges you do not use. Pleas enote that if you do this on a long term basis it is liley the head will dry out and may damage the head - use this advise to get urgent prints out.
Sep 08, 2007 | Office Equipment & Supplies
128 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
