Question about Intermec Computers & Internet
Intermec CN70 not responding.
Problem with Intermec CN70. When I put battery - screen is blank and there is just green light shines and nothing happens. I`ve tried few things which I found in Google but it didn't help. Maybe You have any idea how to fix this BIG problem.
  • 1019 Answers
SOURCE: Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
Posted on Feb 24, 2008
frankzjm
  • 191 Answers
SOURCE: NO VIDEO OUTPUT FROM LCD OR EXTERNAL MONITOR ON TOSHIBA SATELLITE L20 LAPTOP
you may do follow steps
1) eheck memory : reseat all RAM or change other same model RAM
2) take out wireless card at back of laptop MINIPCI. try it
3) still nothing run, your otherboard hardware damaged, need to change the motherboard. the parts please reference here
http://shop.ebay.ca/items/__Toshiba-Satellite-L20-motherboard_W0QQ_kwZToshibaQQ_kwZSatelliteQQ_kwZL20QQ_kwZmotherboardQQ_ckwZlaptop?_trksid=p3286.m104.l1200
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 22, 2009
  • 34 Answers
SOURCE: psp wont power up .
It may be a bad power switch. If you have another psp, you can pull the switch board out of the working PSP and put it in the broke one. It is also possible it may be bricked. Did you try a FW update before the problems started?
Posted on Jul 03, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Posted on Jul 21, 2009
  • 23 Answers
SOURCE: my 53 hdtv 1080 big screen the green light in
Unplug for a few should correct!
Posted on Mar 04, 2010
Reset intermec cn70
There are 3 ways to reset the device:
Warm Boot - When an application becomes unresponsive.
Press the Yellow Power button (also referred to as the IO Button) and select the reboot option.
Cold Boot - When device itself becomes unresponsive, will loose any cached data.
Press the Yellow Power Button (also referred to as the IO Button) to suspend the device. Remove the battery pack and press the reset button in the battery compartment (Round rubber button). Replace the battery pack and press the yellow power button or IO button. The blue Intermec startup screen appears.
Clean Boot - When device itself becomes unresponsive and cold boot fails, device will be restored to factory state, all data and installed applications will be lost except for data stored in Flash Storage.
- Firmware 1.50.19.0013 and prior -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) and volume down button (the lower
button on the right side) together until a message box appears on the screen stating the clean boot. Press the volume up button (the upper button on the right side) to confirm the clean boot.
- Firmware 1.62.27.6 and later -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) for 8 seconds. Message box will appear stating to release the power button. Press button number 1 then button number 2, confirm again by pressing button number 1 then number 2 again. Message box will state that the device is clean booting.
Jun 20, 2014 | Intermec CN70 Handheld Mobile Computer...
Scanner setting
Got to the following:-
Start >> Settings >> System >> Intermec Settings
You are then presented with all the settings you can change within teh device. From here got to:-
Data Collection >> Internal Scanner >> Symbology Options >> Postable
You are then presented with an input field. Enter your (13) here and hit [OK] to save and exit.
Use notepad on the device to check that the 13 is placed at the end of the {Barcode Date}
I confirmed this on a terminal we have here and it worked 500011972829613
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 03, 2012 | Intermec CN70 Handheld Mobile Computer...
My monitor won't come on, the green light blinks, but nothing shows up on the screen at all. i've already changed the video card but that did not fix it. prior to changing the video card, once in a while...
try shining a light directly on the screen to see if youve got a backlight failure, if you have there will be an image on the screen but nothing lighting it from behind thus making it seem blank, if that is not the case id start with the vga cable and work from there
Sep 26, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
While im plaing my psp, the screen freezed and i restarted it, when i turned on my psp (theres a green light) nothing happens the screen is empty then a few minutes the green light gone what happened
I guess you have custom firmware. If so, you can use a pandora battery to solve the problem. If you do not know how to make a pandora battery or if this doesn't work send me an email or add me on eclipse_09_28@hotmail.com. But pandora is most likely to be the solution. I had the same kinna problem but I was updating it thats the only difference. The green light is on and the screen was blank and then the light turned off. So I used a Pandora Battery and it fixed. :P
May 24, 2009 | Sony PlayStation Portable (PSP) Console
I have a dell inspiron 5000e that won't power up. the battery is dead but the adapter works. after pressing the power button the left light beneath the screen turns a solid green and the center light...
As per the symptoms given by you it seems like a motherboard problem. Follow the steps on the link below and it would suggest what part needs to be replaced.
http://tinyurl.com/6xxv4h
thanks
proton
Aug 02, 2008 | Computers & Internet
Monitor displays breifly then goes to blank screen
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Won't turn on.
"If your Zen is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Sep 24, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Screen goes blank when I plug camera into computer
I have to say Mac's I know nothing about. But the simple way would be to purchase a universal USB card reader- and use that.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Sansung digimax s5oo
close the lens on the camera all the way!
Oct 15, 2006 | Samsung Digimax S500 Digital Camera
Computers & Internet Logo
180 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
