Question about Hitachi Gst Hitachi CP-RX78 Projector
Lamp indicator after power on, it will then show the lamp indicator
I have replace the lamp but any how i am not getting any response from projector. As after replacing the lamp projector was ok. It shows all the thing but second time. No response. pl suggest
hi,
you didn't mentioned any thing about the indications. is there is any indication on the projector. if projector have some problem it will show the indication for the same using its self diagnosing system.
just do one thing check the power cable and the power at the socket to which you have connected the projector. if these are ok and the projector have no indications on its panel, then the smps power supply in side the projector have some problem. if so it is difficult repair the smps by the user. need good knowledge of electronics servicing, because there is harmful high voltage points.
Is there is any indication on its panel, then if you discribe the same will provide you the exact solution .
Also try to check the inserted new lamp , lamp cover is it properly closed etc.
if the projector starts try to reset the lamp hour
1. Go to its menu select option2
2. From the option 2 menu select lamp runtime
3. Press and hold the enter button for approximately 3 seconds
4. After resting just power off your projector and turn it on again.
Also check one more thing
The "CONTROL KEY" may be set to "OFF". In order to set the "CONTROL KEY" to "ON"
without using the remote control unit, keep holding down the ENTER button on the projector and press the MENU button for more than 2 seconds.
ok
Apr 04, 2011 | Panasonic Videoprojector PT-LM1E...
Hi i just replace a new lamp for my panasonic but the message on the screen still show u need the reset the lamp hour meter ! please show me how to reset the lamp hour meter
Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen will indicate that the lamp has been reset!
NOTE: When lamp time reset is finished, the LAMP indicator goes out!
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic Televison & Video
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Epson ELP5000 bought from surplus; plug it in and the power indicator glows orange and the lamp indicator is not lit. Opened the lamp unit and it is clearly blown. The user manual indicates that the lamp...
    turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
    means the lamp is fault,and other parts is working well
    Have a nice day!
    We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
    wheel,
    motherboard, powersupply ... with high quality and competitive price.
    Lampdeng Limited
    Jerry
    May 15, 2010 | Epson Replacement Lamp Projector Lamp For...
    EPSON ELP5000 bought from surplus; plug it in and the power indicator glows orange and the lamp indicator is not lit. Opened the lamp unit and it is clearly blown. The user manual indicates that the lamp...
    It is an indication that the projector is in sleep mode. Press power button and check for any changes on the led indicators. If the power turns red, it means unit is hot. check if the fan is working and if the air filter is clean or needs cleaning. If the lamp turns red it means the lamp is busted, You will experience this since lamp is clearly blown. But if both lights are red, it means that the unit is busted and will require service.
    Mar 26, 2010 | Epson Replacement Lamp Projector Lamp For...
    Power and lamp lights flashing red and timer flashing green
    Hi,normally when the 3 led lights show up they indicate its time to replace the lamp.The lamp that is inside your tv normally last around 3000 hrs 1-2 yrs .Pay attention to any weird sounds which could indicate another problem.
    Dec 16, 2009 | Akai PT46DL10 46" HDTV-Ready Television
    Projector shuts down ca 20 sec from start.
    sounds like you may have the wrong bulb and it is being overpowered.
    Dec 15, 2009 | BenQ PE8720 DLP Projector
    Projector's lamp won't light up.
    Change thermostat and service it.Then solve your problem.
    Dec 12, 2009 | BenQ PB8220 Multimedia Projector
    Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
    Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
    The POWER/STANDBY (red) indicator flashes three times
    If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
    The POWER/STANDBY (red) indicator flashes continously
    If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
    The POWER/STANDBY indicator is lit up green (not flashing)
    A sustained green light indicates your TV is on.
    The POWER/STANDBY indicator is lit up red (not flashing)
    A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
    Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
    Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Hitachi Gst Hitachi CP-RX78 Projector Logo
    12 people viewed this question
    Top Hitachi Gst Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Hitachi Gst Office Equipment and Supply Expert? Answer questions, earn points and help others
