Question about Gevalia 50041 / 50443 Coffee Maker
Leaking element need heating element where can I get one?
Where is the water coming from that is leaking from the base of the unit? It is not coming from the drip tray, and we replaced the water tank. The water pools on the right, underneath the water tank t
Does it only leak when making coffee? There are 2 hoses, one that supplies cool water to heating element in base the other one that supplies the heated water from heating element to top of coffee grounds. Typically over time this 2nd hose degrades at heating element connection and begins to leak
Oct 13, 2014 | DeLonghi Perfecta ESAM5400 Black Espresso...
Is there a seal between the nozzle and the tip? I have glue leaking out everywhere??
No, no seal. The heating element is just a heated tube with the nozzle simply threaded into its end. The heating element in your glue gun may be cracked. Or... possibly... you (or someone in your household) got it hot and laid it down and left it that way for a LONG time, and the melted glue backed up inside the heating element. A glue gun should never be laid on its side while hot but idle, especially for long periods of time.
Jul 31, 2014 | Stanley GR100 DualMelt Pro Glue Gun Kit
Frigidaire pld2850 leaking heating element
You will need to replace those rubber or neoprene seals (washers). Which means you will need to pull the dishwasher out and then tip it back about 45 degrees (or more) so you can work on it. Make sure the power cord is unplugged, then you can find and disconnect the wires that go to the heating element, then remove the heater nuts. Then you can pull the element out and replace those rubber washers (if you can get them - try SearsPartsDirect, or repairclinic.com). If you can't get them separately, you might have to order a complete new element which comes with new washers.
Jul 12, 2014 | Frigidaire 24 in. PLD2850 Built-in...
After connecting a drain line to the pressure relief valve of my MR85245 water heater, I now have water leaking badly out of the heating element door.
Turn off the electricity.
Turn off the water valve going into tank.
Open a bathtub spout to let hot water pressure off the tank.
Check top of tank for any leaks.
Open the top access panel and see if element is leaking.
Open bottom access panel and see if lower element is leaking.
The reduced pressure on the tank will slow the leak.
If element is the problem, you can squeak by for a while by turning on the hot water heater only when you need hot water.
Order the 'Marathon MR85245 replacement element' online
http://www.gpconservation.com/rheem/marathon-sp213670-titanium-4500w-lower-element
These elements may be available locally, but they are not the same as 'ordinary' tank-type electric heater elements that you buy at the hardware store.
Buy more than 1 element because the Marathon elements have problems.
One of the reported problems with marathon elements is the high price of stainless steel replacement elements.
Drain tank.
Replace element.
Another resource for water heater information is:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 04, 2010 | Water Heater Innovations MR85245 High...
How to fix leaking heating element? Water appears to be dripping from where one end of the element passes through the tub. Is there a gasket that needs replaced? Thank you D. Brush
Switch off the m/c. Remove the heater and clean the gasket seating area. Replace the gasket. If new gasket not available, clean the old gasket free from oil.
Apply rubber solution on both the ends metal parts. Allow it to dry. Now attach the heater along with gasket. Use after few hours.
May 25, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
How do i change the heating elemen in my Ruud water heater , model # PES40-2T
You'll need a heating element and a heating element wrench. Check your paperwork to make sure you get the right wattage.
1. Turn off the power 2. Drain the tank. 3. Remove the covers from the front panel. Should be one over each of the two elements. Once you've done this, check to make sure that the power is off. 4. Remove the two wires from the bad element. 5. Use the wrench to remove the element. It may be corroded, so take care not to strip out the hex nut. 6. After you remove the element, clean the threads on the tank up a bit with a wire brush. 7. Put a bit of teflon tape on the new element threads, but make sure that you don't have tape hanging out into the tank, and also that the tape doesn't interfere with the gasket on the element. 8. Install the new element. 9. Connect the wires and fill the tank. Check to make sure it doesn't leak before you turn it on. 10. Being careful to not touch the live wires, turn the unit on and allow it to heat up while checking for leaks. Once it's hot and not leaking, turn it back off and replace the covers.
That's it!
Mar 02, 2010 | Ruud Heating & Cooling
What is the the test for the heat element
All you need to do is set your controls to heated dry cycle, and see if the interior heats up nice and warm. You can also check the element by touching it when it is not heated, and note how warm it is, and then when you run the heat cycle. Careful not to burn yourself.
Oct 15, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
I have an old rheemglas fury 22v40 that's leaking from the bottom. What could be the cause? Also, it DOES need replacing, Who does installs at no cost at the time of purchase?
my top element to the hot water heater is working but my bottom element isnt there both brand new elements and im just not getting power to the bottom element but i have power to the top element is it possible that the top heats first and the bottom heats later running out of options!!!
Dec 06, 2008 | Rheem 40 Gallon FVR NATGAS Low WATER...
How to fasten heating element to pot
Had a little problem loosening the nut from the heating element, but once I got it off, cleaned all parts , went to an auto supply store and was lucky to find the right size gasket ( it was a part for a Nissan auto ) , used Permatex silicone gasket sealer, put all parts together, tightened the nut real tight, made all electrical connections, tested the pot with water, heated up real fine , no leaks , Problem solved.
May 24, 2008 | West Bend 33600 Coffee Maker
Heating element broken, water leaking
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
May 20, 2008 | Kenmore 24 in. 15953 Built-in Dishwasher
Gevalia 50041 / 50443 Coffee Maker Logo
12 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
ka4iup
ka4iup
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
