Question about Fisher and Paykel Dishwashers
My Fisher & Paykel double dishwasher won't drain completely
I have clean out the trap and it was clean, however, water is still standing on the bottom after a wash
  • 31 Answers
It may be a blocked hose. First point to check is under the sink where the thin corrugated drain hose joins the sink drain. If it is a double dish drawer there will be two hoses, one black and one white. The black hose is usually from the top drawer. They are held on by spring clamps.
If this is not the problem, post again.
Posted on May 01, 2014
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 1019 Answers
the first things to look for, are the simplist faults.
1:) Check that the Outlet Hose-Pipe Isn,t Blocked-Kinked Or Bent.
2:) Check that the Pump, is not clogged/Blocked or not-functioning.
Hope this helps you start, your fault-finding successfully.
Mike @ Compurepair.
Posted on Aug 02, 2008
I had water at the bottom of my 4 year old plus dishwasher and of course I thought the worst. Did the pump go out, bad impeller, or what else could it be! I started with the easy stuff first and disconnected the drain lines. The drain line runs from the dishwasher to an air gap mounted to my sink, which keeps the drain line from getting an airlock. From the air gap device another larger line runs to the garbage disposal. I used an 8MM wrench to loosen the clamps enough to pull the drain lines off and drained them into a bucket. There really wasn't any resistance to water flow and no real chunks, I was disappointed.
I then took the actual air gap out of the sink by removing a large plastic nut and pulling the devise out from underneath the sink. When I inspected the air gap I saw a wad of hairy, feathery plastic stuff blocking the flow of water. I took the chunk out, reassembled everything and it works like new again.
It is a very easy fix and now even the area under the sink is clean to boot.
Jerry
Posted on Oct 18, 2008
  • 17 Answers
So it sounds to me like it is your "pump" I work for an appliance parts dealer and it looks to me like the pump you need is originally part# 99002750 but then it changes to #6-917641....It runs about $57.00 and you can find this product at www.allbrandonline.com
Hope this helps!
www.appliancepartsonline.net
Posted on Feb 16, 2009
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
E6 fault unable to reset all cycle lights showing
E6 is "Flood switch activated."
Turn the water off and disconnect power to the dishwasher, then empty water from the inside. Clean drain well and check the drain hose at the back. If that does not work, then the water pressure switch is at fault. Call your Fisher & Paykel dealer or Authorized Service Center.
Dec 06, 2011 | Fisher and Paykel 24 in. DS603MFC Built-in...
Hi my F &P dishdrawer unit (DD603) won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Fisher and Paykel Dishwashers
My fisher paykel dd605 does not drain after cylcle on the top drawer can any one help please
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 26, 2011 | Fisher and Paykel 23 in. DD603H SS...
I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
Hi
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Daniel
Aug 07, 2010 | Fisher and Paykel Dishwashers
DD603SS bottom drawer doesn't drain completely. Have cleaned trap and screen. What else could it be?
Trap ans screen are only on the outside, access further down to the propeller and the rotor. Take it out to clean all debris. Pay attention to the marks.Parts are all made by plastic. By forcing it in a place incorrectly may cause them broken. When those debris are out of the in-port, the propeller can drain all water out.
May 05, 2010 | Fisher and Paykel DS603SS Stainless Steel...
Fisher & Paykel double dishwasher bottom dishwasher starts to fill with water then a noise comes on and a flashing F2
F2 is indicating a fault for the motor. This motor has 2 directional operations. One direction of rotating for spraying water for washing. The other for draining at the end of washing cycle. I don't think it is a problem with the motor, but there is some food clogging up its rotation path causing this issue. Need to take out the bottom stainless steel exposing the motor to clean up. I do this some times. Just need to pay attention to remove and put things back properly. Now if you are not comfortable in doing it, then call F&P serviceman. Don't call any handyman, since without knowledge about this dishwasher a person can do more harm than good and you know who will take care of the bill. Good luck.
Dec 27, 2009 | Fisher and Paykel 23 in. DD603H SS...
My fisher paykel DD S03SS dishwasher leaks from the top, & drain
The drawers should not leak unless there is a problem with the vacuum seal. Try cleaning the edges of the doors and operate. You should feel the vacuum is holding the doors. The seals could be faulty or vacuum system may be faulty.
About not draining completely - a possibility is the common drain hose after the U adapter being clogged. Remove the clamp and pass a flexible wire coat hanger towards the main drain pipe. If both drawers are not draining then it is unlikely the drain hose between the U clamp and the dishwasher is clogged. Also make sure the height of inlet water pipe and drain outlet is as specified in the installation manual
Nov 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
FP DD603 draining problem
This device will solve the issue of cross-draining between drawers on Fisher paykel double dish drawers.
http://fisherpaykelparts.net/index.php?categoryid=1&productid=7
Aug 10, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Dishwashers Logo
95 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
