Question about Maytag Stove / Oven / Range Cooktop - 12001853
Fi code model cer3765aac
Where is the model number?
Model number will be located on the data tag. This will be on the back or perhaps inside the over door area.
Mar 16, 2015 | Kenmore 30" Self-Clean Freestanding Gas...
Right front burner stays on high
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Feb 04, 2011 | Cooktops
I need 4 replacement knobs and I cannot find them!! Please help
Hi and welcome to FixYa, I am Kelly. I am assuming that your model number is MGC5430 as listed in your post. If not use this link to find them by entering your model number:
(just note that there are 2 to 5 digits missing from your model number)
http://www.appliancepartspros.com
See this page:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MGC5430
It brings up the following models:
arrow_link.gif MGC5430ADB SURFACE UNIT- GAS arrow_link.gif MGC5430ADC SURFACE UNIT- GAS arrow_link.gif MGC5430ADQ SURFACE UNIT- GAS arrow_link.gif MGC5430ADW SURFACE UNIT- GAS arrow_link.gif MGC5430BDB SURFACE UNIT- GAS arrow_link.gif MGC5430BDB20 36`` GAS COOKTOP arrow_link.gif MGC5430BDQ SURFACE UNIT- GAS arrow_link.gif MGC5430BDS SURFACE UNIT- GAS arrow_link.gif MGC5430BDS20 36`` GAS COOKTOP arrow_link.gif MGC5430BDW SURFACE UNIT- GAS arrow_link.gif MGC5430BDW21 30`` GAS COOKTOP
I used the MAYTAG MGC5430BDB20 as a reference and the BLACK knob is item 6 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5515609&diagram_id=28426062#d28426062 Detailed view is here: http://www.appliancepartspros.com/part_details.aspx?part_id=4100044 If you need more assistance please respond with a complete model number and I will use other sources to loate your knobs. Thanks for choosing FixYa, Kelly
Jan 05, 2011 | Maytag MGC5430 Gas Cooktop
Cant find model no.
You can generally found the model number for a cooktop in a few places. Sometimes the model number is faded or rubbed out. The first place I would check is directly on the bottom of the cooktop that is usually were you will find the model and serial number. Secondly, check on the units electrical box many times the label is to the right or left hand side. Lastly, some cooktops let you lift up the top to clean underneath and you can find the label somewhere around the edges.
Hope that was helpful.
Happy Holidays!
Dec 20, 2010 | Magic Chef 30 in. 8241RT Gas Cooktop
I have a Jenn-Air radiant cooktop, two of the burners run on high no matter where the control knob is set?
Oct 03, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
One burner no longer adjusts temp when moved from 1 to High
Oct 02, 2010 | Jenn-Air JED8430 Electric Cooktop
G. E electric cooktop Model 3JP340BCBB
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at http://appliancehelponline.com/infiniteswitchvideo.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Jun 17, 2010 | GE 30 in. JP340 Electric Cooktop
Infinite switch has failed twice in the last 6 months on my JP350 elec. stove?
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
May 14, 2010 | GE 30 in. Profile JP350 Electric Cooktop
The right front burner will only run on high no matter the setting
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing this. It may be a different model but the testing will be the same. You will need to remove the cook top from the opening to access the switch.You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
May 06, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Thermador Electric Cook Top Circa 1957-58 Model #
SU4-D is your model number. This is a very old cook top. Older units have a catalog number and not a model number. SU4-D stands for surface unit 4 burners.
Jan 28, 2009 | Cooktops
Maytag Stove / Oven / Range Cooktop - 12001853 Logo
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
