Question about NINJA Blender with Single Serve Accs BL660
Single serve ninja cup stuck in base
Cup seems to be in a bind and will not turn. I have tried pressing down and turning since it has to go down to go in. I have tried pulling up a bit and turning and tried to turn without any pressure either way.
Why won't my ninja blender turn on? The red light is blinking, but power is connected and lid is secure.
try rotating the container part 1/4 of a turn to line up slots and press down . then if it does not blend turn another 1/4 turn to line up slots and press down pushing container into base motor unit .
container and screw on blade lid is put in upside down and the plastic posts have to match the base unit to turn on the blender when you press down on container into base unit.
I own and use a ninja blender !.
May 08, 2018 | Blenders
My single serve won't lock in place so it will not work what can I do? I have only had it for two months
If it is still under warranty. Get a replacement or you will be forever trying to fix it.
Dec 14, 2014 | Blenders
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Sep 11, 2014 | Magic Bullet Nutribullet Blender
My ninja BL203Q big canister works fine but the single serve cup won't spin anymore. I've switched between the two cup, make sure its tight, snaps in place, and the teeth seem locked in right but nothing...
I figured it out!!!!!! I'm so excited! Ok, unplug your ninja. With the front facing you, tilt it forward so you can see into the chamber where you would load the cup. See those cut outs around the inside wall where the cup clips in? The one on the right is not like the others, it has a piece that comes up also, that's a sensor.. You can press it down with your fingernail. Apparently when mine leaked, it got into that area and blocked the sensor. Wet the corner of a dish towel and press it against the sensor moving it up and down. When it is moving freely again, plug it in and blend away!!!!! Whoop Whooop! :)
#fixninja #ninjawontspin #ninjaspin #fixmyninja #brokenninja
Jan 28, 2014 | NINJA Blender with Single Serve Accs BL660
My ninja base single serve button is always on, even with nothing attached and it can run with no attachment. I cannot use anything but the single serve.
read your owner manual section troubleshooting. However you must test the control board fro defective, but test the main switch for defective use the multimeter for continuity and replace it
God bless you
Nov 04, 2013 | Euro-Pro Ninja Kitchen System 1200...
Ninja 1100 single serve cup will not come off. it is stuck
I was just having the same problem and looking for a solution...then I found it myself by accident. By pulling up on the cup and then trying to turn it came off pretty easily. I was trying to push down, which seemed to make it tighter.
If you need further help, reach me via phone at https://www.6ya.com/expert/ken_c7355a9e779b6a4e
Jun 21, 2013 | Back to Basics 600 Smoothie Plus Work Top...
Ninja works with single serving attachment but not the large attachment
-Return for refund or replacement. It should never have this problem yet.
Good luck
Mai
Jun 10, 2017 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Blades won't turn when cup is on
check to see if shaft is turning when cup is off if it is somthung is binding it
Sep 24, 2012 | Oster 6804 16 Speed Blender
NINJA Blender with Single Serve Accs BL660 Logo
513 people viewed this question
Top NINJA Blenders Experts
deton8 von Splosion
Bill Boyd
Tom Chichester
Are you a NINJA Blender Expert? Answer questions, earn points and help others
