Iobit update cannot connect web server - Computers & Internet
What I need help with is logging into Facebook from my iPad. Can you help me troubleshoot?
get iobit mobile care, Advanced Mobile Care Android Security for Mobile IObit
run it and try again,if not then delete safari and facebook and download safari,update it then download facebook app.
Jun 20, 2015 | Facebook Social Network
Is there a way to manually update barracuda 300 firmware
Download the latest firmware to your laptop.
Use an Ethernet cable to connect the laptop to one of the "wired" ports on the router.
Connect to the router's web-server interface.
Click into "settings" to find the screen that lets you update the firmware.
Select the downloaded file, and do the update.
Reboot the router.
May 07, 2014 | Barracuda Networks Barracuda Web Filter...
Keek -forbidden(error 408) solution
HTTP Error 408 Request timeout
Introduction
The Web server (running the Web site) thinks that there has been too long an interval of time between 1) the establishment of an IP connection (socket) between the client (e.g. your Web browser or our CheckUpDown robot) and the server and 2) the receipt of any data on that socket, so the server has dropped the connection. The socket connection has actually been lost - the Web server has 'timed out' on that particular socket connection. The request from the client must be repeated - in a timely manner.
408 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
  • Obtain an IP address from the IP name of the site (the site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from the Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '408'. (Last updated: March 2012).
Fixing 408 errors - general
408 errors are often difficult to resolve. They typically involve one-off variations in system workload or operations.
If you see persistent 408 errors, the first thing to consider is the workload on the Web server - particularly around the time the 408 errors were generated. If this is light, then you also need to consider workload on the client system. If the computer systems on both ends of the socket connection seem to be running normally, then temporary Internet surges may be to blame.
Fixing 408 errors - CheckUpDown
This error is highly unlikely to occur on your CheckUpDown account, because there is usually only a tiny interval of time (milliseconds) between our 1) opening of the socket and 2) writing the HTTP data stream through that socket. In exceptional circumstances, this interval may increase because of some operations on our computer systems e.g. we temporarily suspend an executing process and this happens immediately after the socket was created. Or the two steps may follow quickly on our systems, but the second step encounters an unreasonable delay on the Internet. The acceptable interval between the two steps could also be set very low on the Web server e.g. the Web server is very busy, and has become a bit 'impatient' with attempted connections it views as a bit slow.
Any of these conditions may generate an 408 error. But they are all fairly unlikely to occur. In normal IP communications, the time interval between the two steps should be much less than 10 seconds, which should be completely acceptable to the Web server.
I hope this helps.
Oct 23, 2012 | Computers & Internet
HWK UPDATE
Originally Posted by MIRYALA SRINIVAS viewpost.gifhwk Update server has crashed,ODIA TEAM is working to fix the issue ASAP.
So dont update your box.
We inform you when server is working fine
Br.
Vijendra Saini.
dear sir,
i have format my pc then i need to install what should i do????????
Upgrade log:
---------- HWK Update Client v 2.0.8.0 ----------
---------- HWK upgrade started:9/8/2009 8:19:09 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 71327
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-7ACEA977416000C9
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
Jul 25, 2012 | Computers & Internet
Hello, Trying to install this NetGear RangeMax NEXT WN311B into a Pentium III computer with a AMD chip, should be fairly simple just put SSID and Passphrase, - IT WILL NOT CONNECT! Please help
From a computer that uses an Ethernet cable to connect to the router,
access the web-server "inside" the router, and enable "logging" of events,
i.e., attempts to connect, and IP-addresses handed-out by the router to wired/wireless clients.
Then, on the computer with the RangeMax, try again to connect.
Go back to the computer connected to the web-server, and "refresh" the view of the newly-updated "log" file. What new messages are displayed?
Nov 17, 2010 | NetGear RangeMax NEXT WN311B...
How upgrade firmwere for my ZONET(ZSR1134)
With an Ethernet cable, connect your computer to the router,
i.e., do not try to upgrade via "wireless".
Download the updated firmware from the manufacturer's web-site.
Access the "built-in" web-server "inside" the router,
and click to find the web-page that allows you to update the firmware.
Click the "Browse" button on that page to find the file on your computer that you downloaded. Click "Update".
Jan 02, 2010 | Zonet (ZSR0104UP) Router
HOW TO UPDATE ASUS WL-AM604g Wireless Router Firmware I HAVE THR TRX FILE
1. Download the updated software from the vendor's web-site.
2. Connect your computer with an Ethernet cable, *NOT* via wireless, to the router.
3. Access the router's built-in web-server interface.
4. Navigate through the web-pages to the "update firmware" page.
5. Click "browse", and point to the file on your computer that is the updated software.
6. Click "update".
7. Hopefully, BC Hydro wil NOT cut your AC power while your router is updating.
8. The router will restart.
9. Done.
Dec 14, 2009 | ASUS WL-AM604G Wireless Router
"Pocket PC 2002 Update 1.0"
Microsoft Pocket PC 2002 Update 1 official statement This document provides useful information for end users and IT professionals to successfully update Microsoft® Pocket PC 2002 with the Microsoft® Server ActiveSync® client. It also outlines improvements to the Pocket PC 2002 software included in the update. New Feature: Microsoft® Server ActiveSync® client gives users the ability to synchronize directly through Microsoft® Mobile Information 2002 Server with their Microsoft® Exchange Server. Improvements: Improved support for Point-to-Point Protocol (PPP) connections to correct problems experienced when connecting to read e-mail or browse the Web while away from the office. Improved connection support in instances where a specific Internet Protocol (IP) address must always be used. Connection Manager no longer reverses static IP addresses and Domain Name System (DNS) server names. Improved Pocket Outlook Object Model (POOM) support for additional programs you can download or buy for your Pocket PC 2002. If you encountered problems with new programs crashing on your device, this update will help prevent future crashes. Improved viewing of Wireless Application Protocol (WAP) pages. Improved e-mail support for Simple Mail Transfer Protocol (SMTP) servers. Further improvements have benn made in the following features: PPP Networking Connection Manager POOM (Pocket Outlook Object Model) WAP Inbox To download this MS Pocket PC Update 1.0 from our Download files area click here Download and unpacking instructions: To download the file, simply "click" the desired file or link and select save to disk. Download the file to a known directory on your hard disk drive. For example: c:\Temp Open Windows Explorer and locate the "downloaded file" on your hard disk drive. Use an unpacker program to extract the files to a known location on your hard drive. The shareware WinZip unpacker can be downloaded from http://www.winzip.com
Sep 07, 2005 | Toshiba e570
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
