Question about Freezers
S 106 626640
Ice maker over fill or something to cause ice to build up and eventually freeze tray to ice maker. There are three adjustment screws on it. Which one do i need to adjust
5 Suggested Answers
  • 4 Answers
SOURCE: Sub-Zero Under Counter Ice Maker not making Ice
ice stat defective
hot gas solenoid vavle defective
pls post make /model.
if ignis / whirlpool then above points should the trick.
lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
Posted on Feb 26, 2008
Healeyman
  • 1198 Answers
SOURCE: Ice maker only fills the tray partially.
There is an adjustment, but first check your filters, including the one in the inlet of the control valve. To find the adjustment, take the cover off the front of the ice maker. On the side may be a little hole. Look for any 'increase' arrow or such. If not, use a small screwdriver to turn the adjustment a half turn and let it make a load of ice. If it gets smaller, go the other way, use small adjustments. If you can get the owner's manual, it will help a lot. Google your unit for one, you may be able to get it downloaded free from Whirlpool.
Posted on May 05, 2009
SOURCE: Our model 532 keeps over filling the ice maker
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Posted on Aug 11, 2009
  • 389 Answers
SOURCE: I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Ice maker fills and freezes won't dump ice. It will if I hit the test button but not on its own
It sounds like it may be a bad freeze sensor. Consider having it services.
HOWEVER
The first thing I would recommend is removing the necessary grills and clean the condenser area and be sure the fan is operating. This becomes a problem in clean homes because the dirt slides on the floor and into the condenser coil where as the dirt sticks to a dirty floor.
Jun 20, 2015 | Samsung RF260BEAEWW 25.5 cu. ft. French...
Ice maker leaking into ice tray making icebergs
The icemaker could need seal replacement. Check with an appliance parts supplier.
Apr 14, 2014 | Maytag M1TXEGMYB 20.6 Cu. Ft. Top-Freezer...
I have a Sub-Zero 501 F upright freezer. I have never hooked up the ice-cube maker. There is a problem with ice build up in the drain tray and it overflows into the ice-maker. I had a tech in and he put...
sounds like the mullion heater (drain tube heater is open). take back off (after removing all shelves, including the glass tray (remove 4 screws). Pull back out, careful not to pull wires off T'stat. Run the new wires on heater behind evaperator, placing heater down in drain hole. Good Luck
Joe
Aug 09, 2010 | Sub-Zero Freezers
My ice maker has stopped working
The problem is most likely the water control valve on rear of refrigerator.There are two sides on what is called a dual water control valve. If I had your model number I could tell you the part number. The second possibility is the thermostat inside the ice maker is defective. The way to test is to fill ice maker with tap water let freeze and if it dumps and does not refill then the water valve must be replaced. Let me know and please rate my solution, Thanks, Sea Breeze
Aug 13, 2009 | Freezers
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
Aug 10, 2009 | Sub-Zero Freezers
May 05, 2009 | Whirlpool Freezers
I have a Kenmore side/side with water dispenser and ice maker. Ice maker is not making ice, but I still get water. Every once in awhile I see a puddle under fridge (a large puddle). When I pull the fridge...
Hi TJ,
It'll cost around $65.00 to take care of this problem. The problem is the water inlet valve. The part number is 4389177 and can be picked up at your local appliance parts retailer or you can get one online maybe for a better price (just plug the part number into your favorite search engine).
Here's what's happening... The valve I mentioned is actually a "dual coil" unit. One coil supplies the cold water, the other feeds the ice maker. These "coils" are independant of each other, so one coil can fail and the other can keep on truckin', no problem. But what you have is an Ice Maker coil/valve that is weak and it's allowing water to bypass.
Basically the IM valve isn't closing shut completely. Imagine a dripping faucet... that's what it's like except you can't hear the drops, you can only see the results. Imagine drop by drop rising up that tube behind the fridge and into the IM. One drop at a time. These drops of water go into the freezer compartment through the IM fill tube. Now when these little ***** drops slide down the fill tube inside the freezer compartment they flash freeze before they reach the IM. One drop after another... drip drop drip drop. All these little droplets of water eventually form a glacier inside the fill tube.
OK, now we're at the point of glatiation. The fill tube (just behind the ice maker) has completely frozen solid. Now... when the IM "calls" for water to refill itself, the (failed) valve opens up and lets full pressure through. But where is this water/pressure going to go? The pressure builds inside the 1/4" water line until it can't handle it any more, the pressure looks for the path of least resistance. That path is the connection that you found loose. It blew out because the fill tube (into the freezer) is blocked with ice and the reason it's blocked is because the valve isn't shutting off completely.
That's alot of words to say this... it's an easy fix. Get the valve (above). Pull the fridge out. Unplug it. Turn the water off at the wall. Remove the water line going into the valve and set aside. Remove the cardboard panel. Remove the 2 screws holding the valve to the fridge. Pull the valve out. Note the electrical and tubing connections carefully. Get your new valve out and install the electrical and tubing just like the old one. Then rebuild, turn on the water and look for any leaks (use a flashlight and take a minute or two here... finding a leak now will save you alot of misery later). Replace the cardboard and plug it back in.
There ya go! Your first major appliance repair job done successfully? Priceless.
SG
Mar 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
GE top freezer refrigerator automatic ice cube maker leaks water into the freezer, and eventually on the floor. Water seems to be coming from the area that fill up to make more ice cubes.
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
Mar 12, 2009 | GE Freezers
ice stat defective
Feb 20, 2008 | Freezers
Freezers Logo
63 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
