Question about LG Refrigerators
Temperature sensor location - LG Refrigerators
Where is the ambient temperature sensor located ?
images for 2008 Chevrolet HHR LT Where is the .
Outside Temperature Sensor - Chevy HHR Network
www.chevyhhr.net/forums/...hhr-4/outside-temperature-sensor-30594/
Jul 9, 2010 - I had the outside temp sensor go on my 99 Buick. I don't know where it islocated on the HHR, but it was just a plug in sensor. Take out the old, stick in the new.... 2008 HHR LS 2.2 L Auto Built: 12-19-2007. Bought: 4-26-2009 Location of the ambient engine temperature sensor.... Help ...
Mar 26, 2013
Engine Temperature Sensor
Oct 6, 2011
Outside Temp Display
Dec 19, 2008
Outside air temperature problem
Oct 30, 2007
More results from www.chevyhhr.net
Jan 25, 2016 | 2008 Chevrolet Chevrolet HHR LT
97 lincoln continental location of IN-CAR TEMPERATURE SENSOR
i think it is refering to the engine temp sensor ,not a sensor actually located in the inside of the vehicle,on this model the coolant temp is controlled by the cylinder head sensor ,see attached shematic hope this helps3f4e7974-fe11-4e87-aff830d78ba450db.png
May 09, 2014 | 1997 Lincoln Continental
Location air temp sensor
Location of Intake Air Temperature Sensor:
The intake air temperature sensor, which is mounted on the mass air flow meter, monitors the intake air temperature. The intake air temperature sensor has a built-in thermistor with a resistance that varies according to the temperature of the intake air. When the intake air temperature becomes low, the resistance of the thermistor increases When the temperature becomes high, the resistance drops .
Apr 24, 2014 | 2009 Toyota Corolla
Where is the tempurture cooling sensor located on a 1994 buick regal
The coolant temperature sensor is a thermistor mounted in the engine coolant stream. A thermistor is an electrical device that varies its resistance in relation to changes in temperature.
For 2.5L engines, the coolant temperature sensor is located on the left side of the cylinder head.
For MFI engines, the coolant temperature sensor is located on the intake manifold water jacket or near (or on) the thermostat housing.
Fig. 1: Engine Coolant Temperature (ECT) sensor and connector
Fig.: Engine Coolant Temperature (ECT) sensor location-3.1L (VIN T) engine shown
Hope this helps (remember to rating this and leave an testimonial comment about this free answer).
Oct 10, 2011 | 1994 Buick Regal Gran Sport
Locationing temp sensor on 95 rodeo 3.2
There are SEVERAL temperature sensors on your vehicle (battery temperature sensor, intake air temperature sensor, evaporator temperature sensor, etc....you really should specify.
I will assume you mean the Engine Coolant Temperature (ECT) sensor.
If this is the one you are looking for, it is located at the rear of the intake manifold on the left side.
Jul 09, 2011 | 1995 Isuzu Rodeo
Cobalt coolant temperature sensor diagram
COBALT THE 2.2L AND 2.4L COOLANT TEMPERATURE SENSOR LOCATION IS LOCATED ON THERMOSTAT HOUSING.THE 2.0L ENGINE COOLANT TEMPERATURE SENSOR LOCATION RIGHT FRONT PASSENGERS SIDE CORNER OF THE CYLINDER HEAD NEAR THE VALVE COVER.
Aug 20, 2010 | Chevrolet Cobalt Cars & Trucks
Where is the iat sensor located on a 1999 chevy cavalier 4cyl
The Intake Air Temperature (IAT) sensor determines the air temperature inside the intake manifold. Resistance changes in response to the ambient air temperature. The sensor has a negative temperature coefficient. As the temperature of the sensor rises the resistance across the sensor decreases. This provides a signal to the PCM indicating the temperature of the incoming air charge. This sensor helps the PCM to determine spark timing and air/fuel ratio. Information from this sensor is added to the pressure sensor information to calculate the air mass being sent to the cylinders. The IAT is a two wire sensor, a 5-volt reference signal is sent to the sensor and the signal return is based upon the change in the measured resistance due to temperature.
Fig. 1: The IAT sensor is located in the air cleaner outlet tube-2.2L engine and 2.4L engine
Hope helped.
Apr 11, 2010 | 1999 Chevrolet Cavalier
Sensor locations
air intake look at snorkel it could be part of mass air flow check intake for eng coolant
Aug 29, 2009 | 2003 Ford F150 Regular Cab
97 Pontiac Sunfire - where is the temperature sensor located?
the coolant temp sensor is located: Under hood, driver side, upper engine area, below valve cover, mounted in cylinder head
May 05, 2009 | 1997 Pontiac Sunfire
Location of coolant temperature sensor
Maybe this will help . although this is from a 1997 Caddy.
Cadillac DeVille Engine Coolant Temperature (ECT) Sensor Location62451583.gif
Nov 20, 2008 | 2004 Cadillac CTS
Refrigerators Logo
14 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
