Question about TurboChef TORNADO Electric Oven
F5 error with new plate and settings
We switched to the new plate instead of grate inside and they reset our cook settings and now we are getting an f5 magnetron plate error when we use the new plate
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: I have a turbo chef oven, I have F1 and F5 error on the display! Any suggestion?
Troubleshooting...
Faults Requiring Service Call
If one of the below faults appears on the oven display, call 800-90TURBO (88726) or +1 214-379-6000.
* F1: Blower
* F2: Low Temp
* F3: Mag Curr
* F4: Monitor
* F5: Mag Temp
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Posted on Nov 01, 2011
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
Frigidaire f5
Hell Gina, thank you for your inquiry!
I understand you have already tried resetting the range. It is important to wait roughly ten minutes and then turn the unit on. Since the error code F5 reappeared, it typically indicates a communication error between the power board and UIB (user interface board). In this case, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is order and installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Sep 06, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
F3 and F5 errors when first trying to start oven or in the middle of cooking will also get them Mostly F3
F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC).
Aug 12, 2010 | Maytag CWG3100A Gas Single Oven
I want to re-set high temperature limit control,
if you open the oven door all the way, then, look under the control panel (where the top of the oven door seats) you will see a plate that has 6 to 8 screws holding it in place.Remove the screws of that plate with a phillips screwdriver.You will possibly need a flashlight to look inside the space where the reset switch is located... but it is THERE. Make SURE that you TURN OFF the circuit breaker or... UNPLUG the range... B4 you proceed to reset. Look for the Red Button on the back side of one of the limit control switches. Press it in till it clicks. (sometimes you'll hear it... sometimes you wont). Plug baack in ro reset your breaker switch, Turn on your oven and see if it works. If it does... then replace the vent plate close your oven door and now your cook"n with gas...well... electricity really.
May 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Jan 19, 2010 | Maytag 30 in. Electric Single Wall Oven...
When cooking will get an occasional f2 or f5 error code
HI, This seems to be another ERC issue. the temperature sensory circuit is malfunctioning. the oven will not operate while this condition exist within the ERC. This malfunction will allow your oven to over heat and may cause a fire. The second issue will be that the relay drive circuit is malfunctioning as well. If you cant cancel the error code and continue with normal usage, you will have to replace the ERC once more.
Please rate and god bless:)
Apr 05, 2009 | GE 24" Built-In Single Gas Wall Oven
I have a whirlpool/kenmore plus range that came with our house when we purchased it. Former owners did not leave a manual for it. The numbers on it are 95779890 and serial RJ3516457. I wanted to "auto...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$TERGD
Feb 26, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool accubake oven error code
It may just be a door switch
Dec 18, 2007 | Whirlpool RBS305PDS Electric Single Oven
Electric oven model 790.47892601
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Oct 28, 2007 | Kenmore 47834 / 47832 / 47839 Electric...
TurboChef TORNADO Electric Oven Logo
15 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
