Question about Refrigerators
How do I defrost the freezer only on a bush BSFF55174 fridge freezer
Can I defrost the freezer while the fridge is still working?
Master_Tech
  • 770 Answers
SOURCE: fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Posted on Feb 22, 2008
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
Illeagle
  • 525 Answers
SOURCE: proline pc178a fridge freezer still
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided.
http://www.repairclinic.com/0088_4_1.asp#Level1_1
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Unfortunately, we can't describe all of the possible problems and repair solutions here. If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
  • 115 Answers
SOURCE: fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Posted on Jan 03, 2009
notsomot
  • 67 Answers
SOURCE: freezer and fridge don't cool at all. everything else works fine
Heya,
There is a fault with samsung fridges that when it goes on defrost it will not start the compressor or the fans again. If you turn on the power the fridge should run for a couple of hours and then stop if so you will need to get a tech out to order a samsung yellow sensor and a fridge defrost isolation sensor. If the fridge does not work at all if you would like i will talk you a couple of little checks before calling someone out.
Hope this helps
Posted on Jan 08, 2009
Hi, I have a frost free bush fridge freezer. All of my food has been defrosted. The fridge part is working fine. Any idea if there's something I can do to fix the freezer part? Thanks
turn the temperature dial for freezer to a bigger number and see if it gets colder . if not you might need a repairman to check the freon
Jan 23, 2017 | Frost Refrigerators
Bush fridge freezer need coldest setting for fridge 1_7
freezers settings are the larger the number the colder the freezer as against fridge settings where the smaller the number the colder the fridge
Aug 29, 2016 | Bush Refrigerators
Bought Bush fridge freezer 13 months ago. fridge broke down twice with same problem. defrost timer. Can i complain to bush
you can ask again for it to be looked at repaired
even if it is out of warranty
fixed twice during warranty period (for free i hope )
if point of sale will not refund or repair or replace fridge freezer
you will need lots of paper work receipts of repairs and calls and conversations made etc etc
then you have to take the company /manufacturer of the bush fridge freezer to small claims court and try to get money back
parts list
http://www.espares.co.uk/browse/at1084ma732/fridges-and-freezers/bush
Jun 30, 2016 | Bush Refrigerators
Just got a bush combi fridge freezer the chilled compartment is frozen,and the milk froze in the door turned it low but still happened we only got this yesterday.
Yes more than likely u have a bad defrost terminator in the freezer , its connected to the evaporator coils its a small round like object with 2 wires going into it. the other source may be the defrost timer itself. U can check it by locating it in ur fridge usually top middle area. under it u will see a tiny hole or slot, if u stick a small screwdriver into the slot and turn clockwise slowly till u hear a click 1 click not 2 if its stuck out of defrost, it will not go into defrost? the second click should take it out of defrost cycle. Another thing which may be wrong is ur heating element itself has gone bad u can also check it with a multi meter for continuity.
Mar 07, 2015 | Bush Refrigerators
Fridge freezer warm 2touch on outside and water lying in bottom of fride
1. Defrost timer failed, check to see if it is running at all over a half hour. If not, look into the defrost timer. This also drives a heater around the door.
2. Door not closing fully.
Aug 03, 2014 | CDA GENUINE Refrigerator Fridge Freezer...
My fridge freezer is less than 2 years old and the freezer is not working could it still be under warrenty?
If your fridge is self defrosting then you probably have a stuck defrost timer motor/switch. I can usually be found on the bottom of the front ourside of the fridge. You can try to advance it with a screw driver until you hear a click and once you do hear that click the fan and the compressor should turn on. Ifthey do then you will need to have the defrost timer replaced. After two years I doubt it is in warrenty. The only things that should be in warrenty is the compressor and all of the related tubing in the hermedically sealed unit..
I have had this problem many times and since I am a retierd HVAC engineer I was able to fix these defrost timers, mainly the actual motors that had dried bushings. You would first have to take the timer apart and get into those bushings and use a small amount of a good light oil like 3 in 1 oli. That usually does the trick.
Hope this helped you. If it did then would you please let me know, I would be courious to know.
Good luck,
Marty
Jun 26, 2014 | Beko Fridge/freezer Thermostat Genuine...
I want to know if the fridge automatically defrosts
frost free has a defrost system. except really small units
Sep 14, 2012 | Refrigerators
I HAVE A HOTPOINT REFRIGERATOR AND LATELY IT DOES NOT GET COLD ALTHOUGT THE TOP FREEZER IS FINE I TOOK THE THE REAR PANEL OFF INSIDE THE FREEZER AND IT WAS FULL OF ICE WHAT CAN BE CAUSING THIS PROBLEM AND...
defrost your unit for about 2-3hrs..check the fan fan if the bushing has no wiggle, make sure the damper that control the air from top going to fridge is open..you can also check the timer of defroster if it is still working
Sep 13, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Freezer Icing Up
Try contacting the hotline again and ask them if the freezer has a frost sensor on it. If it does, the sensor is not kicking the thermostat to allow for the unit to defrost.
Oct 21, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
