Question about Dryers
Kenmore electric dryer #110.82822102 will not dry clothes on high heat setting. Coil comes on shuts off after one minute cycles back on after a fem minutes but shuts off after 5 seconds. Outlet discharge temp only 94 degrees
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Posted on Aug 04, 2007
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
maklean
  • 1665 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 | Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Model # 11061082000 electric dryer....elite kenmore
you can't get any parts for this dryer the computer board is no longer available,must be old technology replace it.
Dec 28, 2017 | Kenmore Elite HE4 Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Flame only stays on for five minuts. After start
the flame doesn't stay on the whole drying time, it cycles.The thermal fuse allows machine to work and heat up but the cycling thermostat directs the flame to come on and shut off. Do your clothes dry fine?
Mar 04, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore dryer, electric
forget temp ck..first ck air flow at rear of dryer be sure strong air flow present if not remove back ..remove 4 screws holding blower housing to inside wall remove the 2 screws under lint screen on top ..clean blower housing if housing clear ck vent line all the way to end outside for restrictions ..reinstall line to dryer be sure not to crimp or flatten hose when pushing dryer back to wall ...quick ck dry a load with rear vent hose disconnected if cks ok definite vent restriction
Dec 05, 2008 | Kenmore Dryers
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Kenmore Electric Dryer 68731
If still heating, clean out vent and check for kinks. Also, REMOVE PLUG FIRST!! Remove back and remove four screw holding filter duct assembly at bottom left. Pull duct toward rear and reach into bottom of duct and remove lint. Also, wash out filter screen.
Nov 17, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
