Question about Dell E173FP (Black) (Dark Gray) 17" LCD Monitor
E173FP 17" LCD Monitor Problem
My screen seems fine except the brightness/contrast adjustment box keeps comming up. I have tried adjusting with the buttons but the box keeps coming back.
Any help will be appreciated
  • Scott77 Dec 13, 2007
    I have the same problem. It seems like a virus to me, but my anti-virus doesn't find anything. I went to the main menu on the moniter and changed the display time to five seconds and locked the OSD display. Now all the appears is a smaller box showing a lock which goes out in five seconds. It is still annoying, but less intrusive then before. Hopefully, some one will determine a permanent fix for this problem.
Posted on Dec 13, 2007
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
The brightness/contrast menu keeps popping up and scrolling through the exit, brightness and contrast options. It is a Dell E173FP monitor. I have tried disconnecting and reconnecting the cables and...
Try pushing the buttons for the brightness if it does the same thing you need to replace it, the buttons might be damaged already by pushing too hard or it got stuck.
If this is just a new LCD monitor about 1 to 2 years old contact tech support of dell so you can get this replaced.
Jan 30, 2010 | Dell E173FP 17" LCD Monitor
My Dell E173FP adjusts its own brightness I was hoping I could fix this problem myself but I am willing to spend some money to get it fixed the only other solution possibilities I have gotten is that I...
Sounds like dynamic contrast. Have you looked through the settings on your monitor to disable any automatic functions such as dynamic contrast enhancement?
Oct 19, 2009 | Dell E173FP 17" LCD Monitor
Need a manual
I have downloaded the manual from Hyundai website en_man_monitor_lseries_l52s.zip
Jun 19, 2009 | Hyundai ImageQuest L70N 17" LCD Monitor
Contrast and Brightness require adjustment
hi im josh in cebu phils. Maureen may i help you? If it happened yesterday that the contrast box keep on coming. there's a problem in your monitor.so try to check the buttons if covered with dust cleaning may solved the problem.Maureen if you have the manual use it in adjusting the resolution and if you dont have try to press the button mark + or increase just press both of the to the brightnest as posible so that you may be able to proceed another action. thats all for now.hope i helped you.good luck.
Feb 26, 2009 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
VA721/Windows 2000 - contrast/brightness settings grayed out
The monitor is probably set to sRGB under "color adjust".
Change it to 6500K, which is default, and you should be able to adjust brightness and contrast.
Jan 01, 2009 | ViewSonic VA721 17" LCD Monitor
Brightness and contrast screen in center of monitor and can't remove it
the micro switches on the monitor are getting short which is triggering the menu, try to clean it with a switch cleaner or check if the switches can be replaced, do this only if u r an expert in handling things like this or take some proffessional assistance.
Dec 15, 2007 | Dell E173FP 17" LCD Monitor
Blank Screen, power light is steady green
have you tried adjusting for the brightness and contrast of the monitor. does any menu comes out if you press any buttons of the monitor except power of course!
Nov 16, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Dell E173FP 17-inch Flat Panel Color LCD Monitor
The dell monitors are bad with capacitors going out, check caps in power supply and video board. You can use a can of freeze, it would be easier that way. Just be careful not to touch anything, because these monitors can shock easy.
Sep 06, 2006 | Dell E173FP 17" Flat Panel LCD Monitor
Dell E173FP (Black) (Dark Gray) 17" LCD Monitor Logo
289 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
